Help with P301 and P303 codes
Old Jul 28, 2012 | 01:26 PM
tieoneon1's Avatar
CIL keeps turning on, replaced coil packs and CIL still comes on after about 5 miles. have also replaced plugs and checked plug gaps. Help!! this is a real pain. Where should I go next. Thanks!!
Old Jul 30, 2012 | 02:34 PM
LoveMyTL-S's Avatar
Anyone?
Old Jul 30, 2012 | 03:29 PM
swoosh's Avatar
takin care of Business in
A code P0301/P0303 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
I would start with spark plugs/gaps (which you already did)....what plugs are you using....our plugs are gaped to 0.044 (i know for most plugs you dont have to gap them)....
are you monitoring your engine timing? was the timing belt job done recently?
have you gotten a compression test done on all the cylinders?
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
