Help. New to acurazine. 2006 Acura TL
9th Gear
I am new to this site and have owned my 06 TL manual transmission for about 6 months now. If anyone could help me out with searching on this site I would appreciate it. Also have been doing plenty of repairs recently so any kind of tips or help with the site or car would be awesome. Thanks.
9th Gear
Guess it would also be a good idea to include the problems I have had lately. Everything pretty much all started happening all at once. I have replaced the power steering pump and power steering reservoir. Flushed and bled the system. New serpentine belt. Replaced front driver side sway bar link( not sure how long old one was broken for.) recently changed oil and oil filter. Changed all spark plugs. This was in the matter of 3 weeks. Next on the list are which still need to be done:
1) need new front brakes and rotors(brembo caliper) not sure which ones to get yet, I could use some help with that.
2) need to replace o2 sensor- bank 1 sensor 1. Not positive on the location of that sensor so any tips on that and also how "fun" replacing that sensor is.
3.) getting a lot of squeekiness coming from front driver side tire. Going to check the wheel bearing. Also just broke the wheel stud on that hub, not sure if that has anything to do with the noise or not.
Please any help, tips, or anything would be appreciated. Also are there any other maintenance services I should do while I'm at it?
9th Gear
Sorry for the late reply I have been very busy with work. I haven't been able to take any pictures recently because when I leave for work it is dark and when I get home it is also dark out. I will be cleaning my car on Saturday so I will take pictures right after. Thank you for responding
Hau_nguyen91
03-25-2016 10:39 PM
ond
03-23-2016 05:47 PM
