Help! Mystery high pitch noise 08 Acura TL
So, my local shop has misdiagnosed this high-pitch noise (almost sounds like a whistle) as a bad fan bearing. They replaced the driver's side fan, and the sound continues. When troubleshooting, we unplugged the passenger side fan and the noise didn't stop either. So I was surprised when they said it was the fan... easy to troubleshoot by unplugging it. But! That's what they said was the problem, so I approved the work. $380 later... noise continues. I still have to talk to them about paying for work that wasn't necessary. They called 5 minutes before they closed on a Friday. So here I am on the weekend trying to troubleshoot it myself.
Here's the weird part. It only makes the sound when the car is in Drive. Once I shift it to Neutral or Park, the sound disappears. This sound appears after the car warms up, and the AC is on.
Help please! I don't want to keep paying for parts and labor for NOT fixing the problem.
Mystery solved. The noise was coming from a newly installed faulty front engine mount with an air/vacuum leak. The mount has an air bladder and is connected to a vacuum line. New mount covered under warranty.
justnspace (06-30-2017)
