Help me. I need help fast. Acura TL 04
So I really need help and don't know where to turn to for help ,So basically I have a Acura TL 04 modded. ,I left the state for 42 days and I forgot to disconnect my battery ,I knew I messed up that I was coming home to a dead car ,( I also have subs and amp) when I got home I tried to jump my car and nothing I took the battery out and got it looked at and they said it was fully dead so I got a new battery sadly I lost some of the screws That keep the battery in ,I installed the new battery but it didn't start after 10 mins it started and everythin was fine ,well then I left again for a day and a half and now the car won't start again idk what's wrong ,is it the nuts im missing or is it something I'm missing ,can someone help
Battery, alternator, starter- depends what it's doing when you open the door (are there lights?) and go to turn the key. What happens? Is there a click? Does the engine attempt to start? Is the new battery dead?
HFL battery drain?
Sounds like something is draining the battery. HFL and Navi are 2 of the culprits. Do a search, there's tons of discussion on this issue.
Donnie Coleman (03-13-2017)
Welcome to the forums.
Please don't post the same topic in three different forums, which we frown on.
I deleted one of your threads and merged the other two threads together since there were replies.
This will also explain why some of the replies seem repetitious.
So I found out the problem ,I have and after market alarm that's connection is also in the starter so if my alarm isn't working the engine work start it's a anti theft system ,so my car alarm remote battery died which was making the engine not turn on ,I switched the battery and my car starts
I would still get the nuts that secure the battery terminals. A loose terminal can cause all sorts or problems, including no starts.
I'm glad you got your car started!
Donnie "got no nuts" Coleman.....
