Help with HID fogs
A6 and TL
Help with HID fogs
Need some help with my HID fogs. I was running 3000k HID fogs before and they woulds sometimes slightly twitch or "flicker". Nothing too serious....today I received my 8000k HID fog bulbs and I put them in and the right side starts strobing and flickering after 30 seconds. The left side has a slight flicker.
I swapped the ballast with a brand new ballast and same problem. I am running a HID Extra ballast and a Xentec ballast, my other new ballast is also Xentec. Could it be the bulbs?
I already have a relay btw!
One other question....how hot does a HID ballast get? My bulbs were on for two min and the ballast was burning hot...same with the bulbs. Ballast+Bulbs are 35W.
A6 and TL
Swapped working side with flickering side and the working side started flickering. Clearly the ballast is messed up. Emailed the company to get a replacement sent out asap!
the overexplainer
It's the ballasts. Unfortunately the Xentecs are notorious for "flicker", or where the beam would "move" like a candle, just google around. I had them and had the same problem. I double checked the grounds and everything with an HID relay. It's because the ballast quality is cheap.
DDM ballasts do not do the same thing. Xentecs are POS.
Aretardedorange (04-16-2012)
A6 and TL
07 tl-s in
I have xentec's that I've been running for a couple years now......SAME SHIT!!! It's intermittent, at first I thought it was because I'm not using a relay. It usually happens when I first turn them on, only a few times was I driving and it happened.
Edit: Mine actually sometimes shut off completely but as soon as I click off and back on they're good to go.
Registered Member
I just got my 3k HID kit today from theretrosource.com. I've never messed with HID's before or know anyone personally that has this kit, but when I can get around to installing it, I'll let you know how it goes.
A6 and TL
Registered Member
Lol, yeah it probably is real quick, but I got the harness with mine for added insurance, so it looks like it will be a little extra work mounting, zip tying things, and figuring out all the connections so it works right. I love how none of these things ever come with any type of directions.
A6 and TL
And yeah no directions or directions in another language (happened 3x to me).
Registered Member
Cool. I also have a harness. A local member, very knowledgeable cool guy Lex (InFamouSLinK) made my fogs independent. Took forever to do! But worth it, makes the car look much meaner when running just fogs or parking lights+fogs.
yeah xentecs arent the greatest...but i have never had a problem with mine...have them in bike and car...only had to replace the car bulb once and this has been for a couple of years...i went with a higher amp fuse...that seemed to help a little
