HELP with HID fog wiring with relay harness
I am really having trouble wiring up the raptor H8 hid fogs. Well first I wired it up WITHOUT the harness, it didn't light up. Now with the harness i have no clue as where to splice it with the oem foglight harness. Now when I try to put my stock nokya hyper yellow bulbs back into the foglight housing and plug it up, it doesn't come on anymore. Did I screw something up? Please help.
I drew this diagram. Please tell me which letter connects with which letter as that will help me illustrate the diagram. Thanks
![](http://i91.photobucket.com/albums/k288/tyg3rsaurusr3x/untitled-10.jpg)
is this the correct way of spicing with the OEM foglight harnes?
![](http://i91.photobucket.com/albums/k288/tyg3rsaurusr3x/hh-2.jpg)
I need a car in
1 Post
you might have blown a fuse for your foglight. check that first
alright for the harness u have one that goes stright to the positive and one stright to the negative of the battery. (the negative could just go to any ground. then you are left with four connector left. One connector is for the relay (it has a relay socket), then there are two socket which plug into the hid ballast, and the last connector is the switch connector. with this just plug it to one side on the oem fog light harness. the other side wont be used.
Sorry for bringing back old thread... But I think I blew the fuse as well. I checked fuse under the hood but it was okay. I even changed it to new fuse but it still wouldn't light up. Are there any other fuse I should check?
Thank you!
Thank you!
