help with hid fog install
Old Oct 2, 2009 | 07:58 PM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
how do i go about removing my fogs on my 07 tl-s...or where could i find this info...or should i just remove the plastics from underneath the car.....any input would be great...thanks in advance
Old Oct 2, 2009 | 09:25 PM
ifirahse's Avatar
SlammedOnKonis
If you're installing a full hid kit, you'll need to remove the whole bumper and mount the ballasts somewhere.
are you using a relay?
Old Oct 3, 2009 | 08:39 AM
07tl-s6spd's Avatar
yes a full hid kit....no relay....anyone know how to remove the fog lights...
Old Oct 3, 2009 | 07:01 PM
Jiggy2dmax's Avatar
Its in the cars manual if you have it, turn the wheel(depending on the side your working on), remove the few clips on the plastic wheel guard and it gives you access to the fogs. I would recommend using a Relay kit since it reduces the chance of flickering and adds maybe 5 mins to the process. I mounted my ballast using zip ties and you do not have to remove the bumper albeit it might make it easier.
Old Oct 3, 2009 | 08:37 PM
07tl-s6spd's Avatar
yea i got manual....what kind of relay should i get or are all of them the same....the hids are 3000k 55w (h8)...i really didnt want to remove the bumper so i will try removing the wheel guards first ...thanx for the info...installing them tomorrow morning
Old Oct 4, 2009 | 07:10 PM
07tl-s6spd's Avatar
it was super easy to install the hids in the fog lights by removing the wheel guard plastics...only thing is i need to get a relay....due to flickering of the hids...so anyone out there looking to do this should get the relay harness as well...
Old Oct 4, 2009 | 07:28 PM
ifirahse's Avatar
SlammedOnKonis
I have a brand new H8 relay harness I can sell you. It's beefy and yours for $20.
Old Oct 6, 2009 | 12:07 PM
1789's Avatar
Respect Freedom
Did you reuse the same lens/lower grille assembly or mount something new with a better light pattern & range?
BoricuaTL
Apr 8, 2016 01:08 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
Silverstead1
Sep 17, 2015 06:45 AM
EE4Life
Sep 11, 2015 10:13 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
