Help! Door handle cable and stripped screws!
Old Nov 24, 2010 | 04:45 PM
ArthurL's Avatar
So 2 nights ago my door wouldn't close, the mechanism wouldn't hook up to the hook on the pillar. But playing around with it, I was able to get the door to close if I lock it before I closed it.
So I figured it was the door actuator that had a problem. After picking up the actuator from the dealership I removed the door panel successfully and when it was time to remove the three screws on the backside of the door that connects to the actuator, the screws stripped.. How would I remove these screws now?
Does anybody know the part number for those specific screws?
I looked up the part on acuraoemparts.com and I think it is: 90103-S7S-003.
Also the cable for the interior door handle broke, does anybody know the part number for that handle?
I also looked it up and I think it is:
72171-SEP-A01
I looked everything up here:
http://www.acurapartswarehouse.com/b...er-handle.html
Thanks!
Old Nov 25, 2010 | 09:20 PM
ArthurL's Avatar
Bump!
Old Jan 12, 2013 | 12:03 PM
ThirdGenTL's Avatar
I had the same three screws strip. Does anyone know the part number? Thanks,
Old Jun 10, 2013 | 04:50 PM
mc_holla's Avatar
Having the same problem swapping out the actuator. Did you ever get your issue resolved?
Note: I think the part number for the screws are 90103-S7S-003 (as noted above)
Old Jun 10, 2013 | 05:02 PM
pohljm's Avatar
Impact driver may help you with the screws
IBankMouse
Jun 13, 2020 12:53 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
4drviper
Sep 23, 2015 07:42 PM
