Help...crazy headlight problem
Old Aug 15, 2013 | 08:01 PM
MUD_DYNASTY's Avatar
Im haveing crazy issues with my 2005 acura tl.
I can cut my lights on, sometimes right or left hid will work, and otherside won't, or regular bulb won't etc etc. Cut them off, then back on, it sometimes will be the oposite. Then nothing but regular bulbs work, or just hid bulbs. Also the marker on the driver will flicker. Car is bone stock. All factory lighting. Has me stumped. I replaced the headlamp switch with new oem part to no avail. Searched and couldn't find any help
Old Aug 15, 2013 | 09:31 PM
csmeance's Avatar
it sounds like an electrical problem for sure! There is a box that controls ALL the lights on the car. It's a small black box located next to the fuse box under the hood. You can replace that and it probably will solve the issues. But before you do that I'd check all the wiring harnesses and make sure they are clipped in properly.
Also I want to ask if you have had a windshield replacement at all, of if its rained heavily around the days where you've had this problem.
Old Aug 15, 2013 | 09:37 PM
Has factory windshield, never changed, and no weather at all. Is the black box actually connected to the fuse box? Do u have a pic? Thanks so much
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
