Help! "Brake" light on dashboard is on! What could it be??
Old Apr 29, 2015 | 07:10 AM
FastGuy's Avatar
Hey guys I have a 05 tl here's my problem. The "brake" light is on for some strange reason, not to be confused with the "brake lamp" light. I've checked the fluid in the MC and it's full, I've checked the E-brake switch and it's working properly. The car had new front and rear rotors, pads, and ss brake lines. I bled all lines according to acura's sequence. I've also replaced the 2 front wheel sensors! Any idea on how I can read this code or figure out what's wrong?
Old Apr 29, 2015 | 10:47 AM
truonghthe's Avatar
try to get it on a HDS to see if there is any code pop up, normally that light mean your ebrake is engage
Old Apr 29, 2015 | 01:30 PM
FastGuy's Avatar
Sorry what exactly is a hds? The ebrake isn't engaged because if it were when I start driving the "release brake" pops up, and it doesn't . When it is engaged and I drive the "release brake" does pop up on the MID
Old Apr 29, 2015 | 02:37 PM
Will Y.'s Avatar
Registered but harmless
Honda Diagnostic System.
My thought is to recheck the connections on all the wheel sensors.
Old Apr 29, 2015 | 02:41 PM
UA7X's Avatar
Could be the brake fluid level sensor in the brake fluid reservoir cap.
If the sensor failed it may be trying to tell you that your brake fluid is low, even if it is at the right level.
Old Apr 29, 2015 | 02:43 PM
FastGuy's Avatar
Well I haven't changed the rear wheel sensors, do you think that a wheel sensor would make this light go on?
Old Apr 29, 2015 | 02:48 PM
UA7X's Avatar
It probably would but if a wheel speed sensor was bad it would probably turn on the vsa light too.. Is it just the brake light on or are any other lights on?
Old Apr 29, 2015 | 02:49 PM
csmeance's Avatar
a wheel speed sensor would also trigger the VSA light on since the car doesn't know the wheel speed. Go to a shop with a code reader and try to get the code read. That will be the easiest way to narrow down the issue rather than throw parts at the problem.
Old Apr 29, 2015 | 03:15 PM
UA7X's Avatar
Sorry I re-read my other post, I meant the brake fluid level sensor in the brake fluid reservoir (it's not in the cap)
Old May 21, 2015 | 10:11 AM
FastGuy's Avatar
For anu one wondering , it was my front right wheel senor wasn't reading .. I believe the wheel bearing went bad causing it not to read. I purchased a complete spindle from the junk yard installed it and poof the brake light turned off
Old Jun 1, 2015 | 04:54 PM
UA7X's Avatar
Thanks for the follow-up and results! seems like most times people have issues and they get lots of suggested repairs and then we never hear back from them lol.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Sep 14, 2015 10:09 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
