Help!!
Old 08-02-2012 | 11:33 PM
DANELSON's Avatar
Help!!
my 05 tl 6sp is making a clicking noise coming from the driver side whenever i accelerate also when the clutch engages during driving. I dont know whats causing the problem. Could it be my axel?
Old 08-03-2012 | 04:28 AM
YeuEmMaiMai's Avatar
check your CV joints. Jack car up and look at axles. typically the boots tear on the outer joints.
DANELSON (08-03-2012)
Old 08-03-2012 | 09:38 AM
d_prada1's Avatar
x2
also is it just one click when you take off?
if so check the torque spec on the axle nut. Some honda/acuras have a tsb for low torque spec of the axle nut.
Pretty much loosen, apply grease, re torque to a little over 200lbs/ft
