Help
Old Jun 14, 2012 | 11:46 PM
DANELSON's Avatar
Help
i was driving my car earlier today and two messages popped up one is a envelope like a text with the number 1 next to it..i dont know what that means? and the other is check the gas cap i looked in my manual and it said to turn off car and check the gas cap and after driving it around 30mph it should go away but no luck what should i do now. im kinda worried..
Old Jun 15, 2012 | 01:27 AM
Will Y.'s Avatar
Registered but harmless
Envelope w/ "1" means Maintenance Minder message "1"-- change the oil, oil filter and rotate the tires.
All the maintenance codes are summarized in your manual in the maintenance section (somewhere after p. 210).
If the gas cap wasn't properly tightened and resulted in a message, it needs to be tightened (3 clicks), then the message may take 2-3 driving cycles before it clears. Let us know if the message has not cleared itself after the weekend.
Old Jun 15, 2012 | 01:53 AM
DANELSON's Avatar
will do thanks
Old Jun 15, 2012 | 01:58 AM
DANELSON's Avatar
ive just change my oil and filter how do you clear it??
Old Jun 15, 2012 | 02:08 AM
Will Y.'s Avatar
Clear the maintenance messages per the manual's reset procedure in the maintenance section:
1. Turn the ignition switch to ON (II).
2. Press the < or > button
repeatedly until the oil life is
displayed.
3. Press and hold the Select/Reset
button for 10 seconds. The multiinformation
display will ask for a
confirmation.
If you are sure you want to reset
the display, press the Select/
Reset button to select ‘‘OK.’’
If you do not want to reset the
display, press the < or >
button to select ‘‘Cancel.’’
Old Jun 15, 2012 | 12:09 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Will is all over it.
Old Jun 15, 2012 | 01:35 PM
DANELSON's Avatar
The notice just went away
