Help!:(
Help!:(
Just got back from the mechanic who replaced my 4 brakes rear and from rotors and pads. Earlier this morning i took the car so he can check this weird noise coming from the trans. Sounds like a clicking but when you engage the clutch the clicking stops. Well he said he didn't find anything wrong that everything was fine. When he replaced my clutch I started getting that clicking. All the gears are fine tho. Well he did my brakes around the afternoon and finished around now and my car feels like its driving on cobblestone road. I read something like this but I can't find it. Can anyone help me.
Was the clutch replaced with an OEM clutch disc/pressure plate? If so, then noise you hear when the clutch is disengaged (neutral) is most likely the throwout bearing. It's supposed to be replaced everytime the clutch is replaced and could have been installed incorrectly.
As for the way the car feels now after the brakes are done, what do you mean cobblestone road? Can you be more specific about whether it feels rough when you're applying the brakes or just driving and not using the brakes?
**WhItE-aNgEl** (12-31-2011)
As for the way the car drives it really could be a bunch of things. What I would check first would be to make sure the wheels are torqued correctly/lugs are tight. Also check the rims to make sure no "balance weights" came off the inside, which would cause vibration as speeds increase.
It's a possibility; if you feel safe "limping" the car to the dealer and it's close, I would imagine it's ok to drive (since you said it drove fine at lower speeds). If you would just want to play it safe, you can get it towed and have some peace of mind.
