Heater question???
Old Nov 8, 2011 | 12:31 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Heater question???
Last couple of days i notice my heater not blowing any air at all, i would but the fan level on full blast but nothing is coming out.. I dont know what i should check on first???
Old Nov 8, 2011 | 02:47 PM
jokerman826's Avatar
Jokerman
so you have no air blowing at all?
Old Nov 8, 2011 | 02:58 PM
invalidalias's Avatar
blower motor or transistor/resistor. more than likely blower motor.
Old Nov 8, 2011 | 07:52 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
No, just some signs of heat but no air at all.. Tried the a/c samething...
Old Nov 8, 2011 | 08:20 PM
Jokerman
definately something wrong with the blower motor. Check to see if its getting power, i.e. fuses.
Old Nov 9, 2011 | 03:30 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
You know which fuse??
Old Nov 17, 2011 | 09:31 AM
madpoz's Avatar
I had the same issue last year. Don't bother troubleshooting the blower motor...follow these instructions to bypass the transistor first http://forums..com/showthread.php?t=506999
Old Nov 17, 2011 | 06:51 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
the link doesnt work, : /
Old Nov 17, 2011 | 08:25 PM
TCBaby's Avatar
That is not cool. Not to thread-jack, but does anyone have the link to the 3g all DIY thread. I lost it.
Old Nov 17, 2011 | 08:51 PM
TCBaby's Avatar
Never mind, I found it.
Old Nov 18, 2011 | 08:26 PM
madpoz's Avatar
If that link is blocked, try a google search for "How to Fix Your Power Transistor Module". The module is the same on several honda and acura cars, and it is a common breakdown item. I pulled the module and soldered in a jumper wire to bypass the thermal cutoff, restoring full functionality to the heater. This should be considered a quick, cheap fix but probably not permanent as this is a safety feature that is being bypassed (although it's debatable how much risk it presents).
Old Nov 19, 2011 | 05:09 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Great thanks madpoz, just needed some direction i might aswell just go ahead and get the new blower since is the same as the resistor ..
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
07Acuradude
Sep 29, 2015 03:01 PM
