Heater problems!!!!!
Old Dec 18, 2009 | 06:11 PM
HarlemzFinest135's Avatar
I have no heat on my 05 Acura TL. I turn up the temp on it and still have no heat..
Old Dec 19, 2009 | 10:35 AM
Hapa DC5's Avatar
אני עומד עם ישראל
check coolant level first, make sure the radiator (not just the reserve) are full. If not it could be the heater core. Start small work your way up.
Old Dec 19, 2009 | 11:13 AM
Majofo's Avatar
It takes time for your system to get up to temp after a cold start. Maybe 3-4 minutes.
If your engine is warm & you still have no heat.. Check for moisture around the passenger carpet. If it's dry then check the heater control valve.
https://acurazine.com/forums/showthread.php?p=11390744
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
07Acuradude
Sep 29, 2015 03:01 PM
