Heater Problem
Old Jan 15, 2012 | 08:41 PM
sam617's Avatar
Heater Problem
Just seeing if any one have the same problem as I have. The heater doesn't get hot when I used the fresh air but when I use the air circulation button the air get warm. If I turned off the air circulation button to fresh air the heater blows cold air in. Is there any fix for this?
Thanks, Sam
Old Jan 19, 2012 | 12:21 PM
LoveMyTL-S's Avatar
Anyone?
Old Jan 21, 2012 | 09:45 AM
Turbonut's Avatar
Try a self diagnostic test to see if any DTC appear.
Turn ignition on
Press and hold the OFF button. While holding the OFF button, press the circulation button 5 times within 10 seconds. Release the OFF button and the self-diagnostic will begin.
If there are any problems in the system, the temperature indicator will light up the segment of (A through S) corresponding to the error. The temperature indicator will then alternate every second between displaying "88" (all segments lit) and error code (A through S). To determine the meaning of the code you'll need to the DTC troubleshooting index.
If there is no problem detected, the segments will not illuminate.
Turn off the ignition switch to cancel the test.
Each part of the "88" indicates, or translates to a specific letter, e.g. top of the first 8 on the driver's side is a C, top of second is a D, passenger side temp, top of first 8 is a L, etc. and each segment indicates a specific problem.
Don't have a scanner so can't load the detection code values, but just as an example, if the top of the first 8 is lit, that would translate to a C:
C-An open in the outside air temperature sensor circuit.
At least you can see if there are any codes to indicate a problem within the system.
Old Jan 21, 2012 | 12:25 PM
Tonywp75's Avatar
Dont Touch My Car !!!
Thanks, Sam
Not sure if i have the same problem, but it sorta sound like what i am experiencing.
1) Heater is off (no Temp is displayed) and cabin circulation is off (Light not on), the vent blow hot air
- I think it just the driver side vents that blow hot air.
2)Heater is off (no Temp is displayed) and cabin circulation is on (Light lite), the vent doesnt blow air
I think i been having this issue for a while, but wasnt sure if it suppose to be that way.
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
07Acuradude
Sep 29, 2015 03:01 PM
