Heat by my feet
Heat by my feet
I wanna kno if anyone knows why i feel heat by my feet when the thermostat is on cool and off and i have the circulation button on to stop the outside air from coming in and i still feel the air by my feet and i want to kno why it does that and how i can stop it
Sounds like air coming in from the engine bay... I'd check around the footwell and the firewall.
Theres a rubber gasket behind the dash around the brake pedal area.Its where your wires come through and prevents engine heat from coming in. That might be either loose or got pushed out. If so you should be able to pull through and set it properly farely easy. I had this problem after i ran my power cable for my sub.
