Headlight relay no power
Old Dec 7, 2018 | 06:41 PM
pauldjackson's Avatar
Having problems with driver's side high beam not working. Replaced bulb, ballast, and igniter. Still didn't work. Took out entire headlight assembly, and tried it on the passenger side. Worked fine, both high and low. Tried the passenger side assembly on the driver's side, and same problem. Can't hear the solenoid working on driver's side. Is there a fuse or some other reason I'm not getting power to the solenoid on the driver's side to switch the high beams on?
Old Dec 8, 2018 | 01:54 AM
csmeance's Avatar
Old Dec 8, 2018 | 05:58 AM
Bad ground is all it was
After checking the schematic, I thought "bad ground, maybe?" Sure enough, once I bypassed and grounded it, it worked perfectly! Thanks for the schematic - it was all I needed.
Old Jan 7, 2024 | 05:55 AM
SeeFutt's Avatar
3rd Gear
Hi, which ground are you talking about? I seem to be having the same issue. High beams not working after I swapped headlights.
Kevin17112
May 13, 2017 04:49 PM
Andy Ng
4G TL Problems & Fixes
Mar 10, 2017 01:41 AM
DoubleSh0t
Sep 29, 2008 11:28 PM
Eedvl1999
Jul 22, 2006 07:58 PM
