Headlight relay no power
Having problems with driver's side high beam not working. Replaced bulb, ballast, and igniter. Still didn't work. Took out entire headlight assembly, and tried it on the passenger side. Worked fine, both high and low. Tried the passenger side assembly on the driver's side, and same problem. Can't hear the solenoid working on driver's side. Is there a fuse or some other reason I'm not getting power to the solenoid on the driver's side to switch the high beams on?
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/958x999/screen_shot_2018_12_08_at_2_53_02_am_beafebd381f13614b3ab212a244094e1e7c578dc.png)
pauldjackson (12-08-2018)
Bad ground is all it was
After checking the schematic, I thought "bad ground, maybe?" Sure enough, once I bypassed and grounded it, it worked perfectly! Thanks for the schematic - it was all I needed.
3rd Gear
Hi, which ground are you talking about? I seem to be having the same issue. High beams not working after I swapped headlights.
Knicee
06-27-2020 08:45 PM
Kevin17112
05-13-2017 04:49 PM
Andy Ng
4G TL Problems & Fixes
03-10-2017 01:41 AM
