Headlight Issues. Help!
Old Oct 29, 2015 | 10:46 PM
SouljaTL's Avatar
9th Gear
Hello, I'm new here. I've just recently purchased a 2008 Acura TL. I noticed the right headlight was out. And they driver side headlight is on but very dim. If I turn off the fog lights, you can barely tell that the driver headlight is even on. How do I go about checking the igniter, I've done research. Is the igniter and ballast separate. The used car dealer said they will replace the entire light assembly. Do you all think that would fix it?! Any info is useful. Thank you.
Old Oct 29, 2015 | 10:56 PM
MonkeyTrucker's Avatar
Life Connoisseur
The light assemblies wouldn't include ballasts.
I'd read up in removing your front bumper, you'll be going down that road soon.
Old Oct 29, 2015 | 11:16 PM
truonghthe's Avatar
if it turn on then the igniter is good, however the ballast is more like a main cause for this problem. You have to remove the front bumper then took the headlight out, OEM ballast locate under the headlight assembly.
Old Oct 29, 2015 | 11:18 PM
Life Connoisseur
Do the high-beams work fine? The bulbs are dual HID / bi-xenon. If high beams work, I'd rule out the ballast and replace the bulbs.
Read up, enjoy, you're welcome.
From a 2004-2006 service manual, similar, but not identical.
File Type: pdf
Old Oct 30, 2015 | 06:39 AM
SouljaTL's Avatar
9th Gear
Ok I'll let you all know how it goes
Old Oct 30, 2015 | 06:43 AM
SouljaTL's Avatar
9th Gear
No the high beams do not work on either side. The driver side light that's dim just does one flick on high beam but it's no brighter. The right side is still nothing. No light on bright or low beam.
Old Oct 30, 2015 | 08:31 AM
polobunny's Avatar
Registered Bunny
What? No, that's not good troubleshooting.
The headlights on the Acura TL use the same D2S bulb for low and high beam. When you activate high beams, you only move a shield out of the way of the bulb using a solenoid in the headlight. The bulb is a single filament, which you can clearly see upon inspection of the bulb itself.
D2S
H4 (dual filament)
Old Oct 30, 2015 | 09:02 AM
Comfy's Avatar
2014 RDX AWD Tech
Are the ballasts located inside the headlights? In that case there's no problem if you replace the entire assembly. If the ballasts are outside headlights then you can test by switching out ballasts / igniter from either side and see if the problem follows the ballasts, igniter or headlights.
Old Oct 30, 2015 | 09:09 AM
SouljaTL's Avatar
9th Gear
Ok good that makes sense
Old Oct 30, 2015 | 09:16 AM
polobunny's Avatar
Registered Bunny
The ballasts are located under the headlights. As MonkeyTrucker said, I'd read up on how to remove your bumper.
Old Oct 30, 2015 | 07:53 PM
truonghthe's Avatar
it will be a great help if you can snap a night with headlight on pic and upload it to here. one low and one on high beam so we can see what are we dealing with here.
Old Oct 30, 2015 | 10:16 PM
SouljaTL's Avatar
9th Gear
Low beam
This is a picture of the lights on the low beam setting.
Old Oct 30, 2015 | 10:30 PM
SouljaTL's Avatar
9th Gear
High beams
Old Oct 31, 2015 | 10:03 AM
guitarplayer16's Avatar
your parking light bulb is out, you'll want to replace that too.
as stated, most likely a bad ballast.
remove the front bumper to get to it.
Old Oct 31, 2015 | 10:39 AM
01acls's Avatar
OP
Tell the dealer to replace the igniter and the ballast instead of the HL assy.
Then use the new parts to diagnose the rt side hid.
Old Oct 31, 2015 | 01:19 PM
truonghthe's Avatar
its the ballast, but to be safe get a new igniter too. Reason why you said driver beam is dim because normally the car design to run on both beam create a wide beam pattern and bright in the middle. Your driver side is fine, but on the passenger you will need to replace the ballast and ignitor. BTW who's cost is this gona fall under? if dealer will cover the cost get new parts. If you are paying then DIY with used part for cheaper.
Old Oct 31, 2015 | 01:33 PM
SouljaTL's Avatar
9th Gear
Headlight repair cost
Hey thanks for your response. And the dealer agreed to cover all cost for headlight repairs. I had them put it in writing, on a paper with the dealer heading.
Old Nov 1, 2015 | 02:27 PM
truonghthe's Avatar
good, now let they replace the entire headlight unit as they insisted.
Old Nov 6, 2015 | 07:02 AM
SouljaTL's Avatar
9th Gear
Update
Sup guys well the dealer finally replace the headlights and park light bulbs. I just want to thank everyone for their
Old Nov 6, 2015 | 07:04 AM
SouljaTL's Avatar
9th Gear
[QUOTE=SouljaTL;15604065]Sup guys well the dealer finally replace the headlights and park light bulbs. I just want to thank everyone for their replies.
Fixed. Right side still looks dim.
Old Nov 6, 2015 | 07:19 AM
You know you have 04-06 TL headlights?
Old Nov 6, 2015 | 07:47 AM
Slpr04UA6's Avatar
-------Tim-------
^Good eye Thanh!
Old Nov 6, 2015 | 04:20 PM
truonghthe's Avatar
yeah saw that too.
ZildJonKim
Nov 14, 2015 09:43 AM
wardak33
Oct 27, 2015 08:06 PM
Poormans-TL
Oct 26, 2015 09:51 AM
wrestrepo
1/2G MDX (2001-2013)
Oct 23, 2015 05:40 PM
