Headlight issue
Old Aug 17, 2010 | 11:03 AM
space_bound's Avatar
Headlight issue
My 2004 TL i noticed that the headlight wouldn't come on some of the time but other times it would. Now it never comes on and I was at autozone and asked him about bulbs and he said that they are expensive but he said that if it would sometimes not turn on and other times it would turn on that it might be the "ignitor". What do you guys think.
Also, what is clearing the lights?
Old Aug 17, 2010 | 11:22 AM
guitarplayer16's Avatar
Clearing the lights is removing the amber from the headlight.
These are cleared headlights:
Old Aug 17, 2010 | 11:28 AM
Yeah that looks sick! Is it easy?
Old Aug 17, 2010 | 11:34 AM
Clearing headlights is time consuming and you have to have patience.
You stick your headlights in the oven at 220 degree for about 20 mins, in order to open them up. there are plenty of DIYs on acurazine
the "ignitor" is called a ballast. you can do a simple test, by switching ballasts from one head light to the other. if the problem follows the ballast, then its the culprit.
Old Aug 17, 2010 | 11:37 AM
Is it hard to switch the ballast? Do you think this is covered by the warranty?
Old Aug 17, 2010 | 11:41 AM
AMUA6's Avatar
ScoobyZINE
There is an ignitor and a ballast.. try swapping ballasts between headlights first and see if that works, then you'll know if it's the ballast. The ignitor plugs in from the ballast to your headlight bulb and then grounds out behind the projector. Althought 9 times out of 10 it'll be the ballast.. You may have a little moisture in the ballast
Old Aug 17, 2010 | 11:42 AM
Sorry for the misinformation. didnt know they were two diff. things.
Old Aug 18, 2010 | 02:35 AM
gungrave's Avatar
Don't to mean to hijack this thread but how do you guys remove the headlight stain that doesn't come out with regular wash that i quess gathered around the headlight over year?
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
