Headlamp repeatedly burning out
Old Aug 22, 2015 | 09:44 AM
baby_igor's Avatar
Still loving my 2004 TL but am having funky issue with headlamps burning out. First one burned out around 100,000 and assumed that was normal. Then the replacement burned out around 130,000 (2-3 months ago) and replaced it then. Now today that replacement just burned out. No obvious problem with water inside headlight enclosure. Could it be the control unit or the igniter?
Old Aug 23, 2015 | 02:33 AM
YeuEmMaiMai's Avatar
replace the ballast
Old Aug 23, 2015 | 06:09 PM
DMZ's Avatar
DMZ
Head a da Family
Try ebaY
2004 acura tl headlight ballast | eBay
Old Aug 26, 2015 | 11:07 PM
csmeance's Avatar
Get yourself a pair of new bulbs, it's bad to run different bulbs from side to side. I highly recommend the Osram CBI's, you can find them on sale for around $130 for the set and they are incredible.
Swap the bulb from side to side and make sure that it's not the bulb that is bad. It could be a bad connection to the ignitor or ballast. You can swap 1 part at a time from side to side to figure out the culprit.
calrow
May 3, 2017 10:21 PM
knight rider
Mar 4, 2016 08:59 AM
Thuneau
Oct 3, 2015 04:19 PM
