having trouble removing headlights
Old May 11, 2010 | 09:47 PM
poormans_tl69's Avatar
CARBON FIBER WDP TL
Question having trouble removing headlights
Im trying to remove my headlights but i was having some trouble..removed all the bolts under the headlights..two that where on the ballast bracket and the two at the end of the lights...now im just stuck dont see other bolts to remove...didnt have much time to play with them but if im missing one hiding somewhere lmk please..i tried to find a diy link but had no luck
Old May 11, 2010 | 10:07 PM
Timb227's Avatar
Fear and Loathing in my
I believe there is one on top as well. Just take your time and look everywhere that a bolt could be. It is very easy, but if you miss one, it'll only make it harder. Did you also take out the two plastic pieces that are under the headlight? The piece that the bumper snaps in to?
Old May 11, 2010 | 10:17 PM
CARBON FIBER WDP TL
Yea I removed the Bumper clips but don't remember if I removed the bolt at the top. I'll check tmoro. Hopefully I have the time
Old May 11, 2010 | 10:38 PM
bforbrian's Avatar
There should be 3 bolts under the hood, near the battery.
2 bolts for the ballast.
1 bolt on the side of the headlight (closest to the door) holding the plastic tab of the headlight and the metal bracket.
1 bolt near the front (radiator), under the DRL (or foglight if you have an 04-06), which, is the most annoying to get to. This bolt is coming straight out at you.
1 bolt slightly to the right of the one mentioned above, which is coming out to the right.
Old May 12, 2010 | 12:44 AM
AMUA6's Avatar
ScoobyZINE
Might I ask why you are removing the headlights?
Old May 12, 2010 | 12:40 PM
mglax13's Avatar
New shoes on my
SEARCH!
https://acurazine.com/forums/3g-tl-2004-2008-93/headlight-front-bumper-inner-fender-w-wash-tank-hid-bulb-scans-garage-e-001-g-001-a-587181/
HairyMonkey019
Apr 22, 2016 10:50 PM
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
Kevin Sami
Sep 22, 2015 09:59 AM
