guess oil leak. what liquid ?
grease that mixed with water, the grease come from your axle boot. Its time for a new axle.
SeongBae Hong (10-24-2019)
it could be the axle boot or the oil filter housing or another gasket in the area. A mechanic will clean the area and see where the drip is originating from.
I see several types of leaks there and there are many potentials in that area:
- oil pump
- VTEC solenoid/oil filter housing
- the yellow stuff looks like coolant mixed with oil/grease
- axle grease
- power steering fluid -> there is a metal to rubber hose connection there that's prone to leak
You need to fix one, clean it up completely, drive again and fix the next leak until you get all of them fixed.
- oil pump
- axle grease
My suggestion would be to clean it all up first, preferable with a pressure washer. It could be any or all of the issues listed by t-rd above, or even other leaks not mentioned. I was going to say rear main crank seal but diagnosis is a crap shoot without cleaning then observing...
