Gas cap message
Old Dec 1, 2015 | 10:48 AM
charmer37's Avatar
Unhappy Gas cap message
Hello,
I have a 2006 acura tl base model and i would like to know how to reset the "tighten fuel cap message"? I purchased a new cap from the dealer and the light still comes on, I notice when i get below a half tank of gas the light seems to always come on. Any advice or other things i need to check out to solve this annoying problem i would really appreciate it...thank's
Old Dec 1, 2015 | 10:59 AM
zubi23's Avatar
U need to get a software update or there might be a small leak so just make sure you rotate the cap three times after filling gas and you should be good.
Old Dec 1, 2015 | 02:40 PM
Vlad_Type_S's Avatar
Registered Bike Offender
It's the purge control solenoid valve brah. There's a TSB on it.
Part #1 here:OEM Acura TL 2006 PURGE CONTROL SOLENOID VALVE parts
Old Dec 1, 2015 | 02:51 PM
sockr1's Avatar
no.
yes. $100 but that light won't come on for another 5-7 years when your TL is pushing 300k miles
Old Dec 1, 2015 | 03:32 PM
zubi23's Avatar
You're right, its the solenoid valve. This happened to me 4 years ago...so memories a bit hazy.
I think the cpu udpate was needed on my car because sometimes when I would be sitting inside and if it was on for longer than 10 mins, I would get some random error message.
Old Dec 1, 2015 | 03:45 PM
truonghthe's Avatar
ECU need to be update due to the CEL will be lit on with code "engine running lean", this is different than tighten gas cap. The update was expand the parameter on the ECU allowance running lean before throw a code again.
Old Dec 1, 2015 | 04:55 PM
Joneill44's Avatar
Everything Vlad said
Old Dec 2, 2015 | 10:26 AM
charmer37's Avatar
Thanks for the info. guys
Old Mar 22, 2016 | 03:40 PM
jbbenni's Avatar
5th Gear
Thanks Vlad. I got the "Tighten Gas Cap" message on the CID, with no diagnostic codes. I just had an emission check, which included a check of the gas cap. So I was sure the problem was the PCV solenoid, as in the TSB. I replaced with an Acura part ($110). Easy operation. But it's been 4 days and half a tank of gas and I'm still getting the message.
Give no drag codes, a tested good gas cap, and a replaced PCV solenoid - what else could it be?
Old Mar 23, 2016 | 09:53 AM
alexb92's Avatar
Try disconnecting the battery and wait a few minutes to reconnect it. Also check and make sure you properly reconnected the harness, and the hoses and inspect them for tears.
raaaaam
Aug 2, 2018 12:01 PM
ericcdong
Nov 28, 2015 05:38 PM
TheyGotMawty
Nov 25, 2015 08:04 AM
