Fuel Filter Replacement
Old Dec 25, 2007 | 11:44 AM
bhaubold's Avatar
I've seen threads here on replacing the fuel filter. One thread shows a tool used to remove the pump / filter assembly from the tank. It also shows this assembly being torqued to I beleive, 68 ft/lbs.
My question is: where can I find this tool? I Googled this tool and came up with nothing.
Thanks for any help you have,
Bob
04 TL AT
Old Dec 25, 2007 | 01:32 PM
01tl4tl's Avatar
did gen3 have a a dramatic change from gen2?
Our car has a sock filter at the fuel pump and should not require cleaning under normal circunstances.
If you managed to put Diesel fuel in, yes you would need to clean everything
A can of Seafoam- parts stores 6.99 a pint, add 1 can to 1/4 tank of gas to clean the injectors and valves & piston tops
nanos
Nov 12, 2015 08:41 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
Skirmich
Sep 15, 2015 06:41 PM
Aleax
Sep 9, 2015 08:04 PM
NSolace
Sep 3, 2015 08:14 PM
