Front (L) power window master switch cover
Old Aug 10, 2012 | 07:01 PM
tl3097flnkr's Avatar
i was vacuuming my car this evening and inadvertently happened to place the vacuum cleaner nozzle on the front power window switch area. The suction caused a part of the cover over the master power window switch to get sucked (the one that you can click to deactivate control of windows from the other seats) - although the switch is still functioning fine it bothers me to have just have the cover over it. Does anyone know if the switch can be replaced and how much it would cost me?
Thanks!!
Old Aug 11, 2012 | 12:48 AM
kibbles906's Avatar
check www.car-part.com
i got a switch for 40 bucks before and just took that cover off that switch and installed on mine cause i didnt want to take door panel off.
Old Aug 11, 2012 | 08:25 AM
Thanks kibbles906 - I didn't know the cover could come off without breaking. Any pointers on taking the cover off would be helpful!
Old Aug 11, 2012 | 08:31 AM
Undying Dreams's Avatar
Wouldn't it be in the vacuum...just take it out and clean it off...
Old Aug 11, 2012 | 04:03 PM
kibbles906's Avatar
or what the guy about said if its in the vacuum it should go right on.
i just pulled it off the new switch and pushed it onto the old one.
was very easy
Old Aug 11, 2012 | 07:39 PM
clsdave's Avatar
2005TL(6MT)
I'd be going through the vacuum bag/container right after it got sucked up. Hopefully this option is still available to you. The cover can probably be cleaned and reused with a spot of glue if necessary to keep it in place. It's a lot less trouble than buying a replacement switch and changing it out.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
08 NBP TL
Sep 8, 2015 08:49 PM
sputik
Sep 7, 2015 01:40 PM
