Front Door WIndow Problems
Old Dec 10, 2007 | 08:50 PM
05TLRIDER's Avatar
So, now that I've had a problem with both my windows, it's time to post something.
First Problem:
I'm driving home from work and the front driver side window was up. I didn't touch anything and I start hearing this knocking noise, like something was catching on the tread of my tire (i was going about 40 down the highway at the time it happened). That would surprise me considering it had just snowed. Anyways, I put my hand on the door and could feel something "knocking." I put the window down and up again and it hasn't done it since. I'm assuming that it was a freak of nature, but wanted some opinions. Anybody else experience this?
Second Problem:
I put the passenger side front window down the other night and it wouldn't go back up. I tried about a dozen times and it would go up about an inch or so and go back down. I pushed the button down again (even though it was already down all the way) and then pushed it up. It did go up, but I don't want it getting stuck on me again. Again, anybody else have this problem, or do I have two freak of nature front window modules?
I should also mention that I do NOT have the KP Technology window roll up module. Sorry for the long write up.
Old Dec 11, 2007 | 08:08 PM
05TLRIDER's Avatar
All these views and no response?!? Come on guys any help at all?
Old Dec 11, 2007 | 09:32 PM
Will Y.'s Avatar
Registered but harmless
It sounds like a misaligned window track problem; there was a TSB issued for it in '04 or '05. Have the dealer correct it if you're under warranty.
Old Dec 11, 2007 | 09:35 PM
csmeance's Avatar
the cold weather is probably causing the windows, and channels to contract, causing that noise. Also the cold isn't the best for lubricants that come from the factory for the windows. Acura should remove channels, clean thouroughly, realign and re-lubricate for smooth operation. Also have them check the motors for the windows, but i doubt both are failing at the same time.
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
TLDude876
Dec 28, 2016 03:18 PM
handsom-hustla
Nov 13, 2015 05:04 PM
08 NBP TL
Sep 8, 2015 08:49 PM
