Front Clunking Noise Solved
Old Jun 30, 2018 | 07:39 PM
algonquinloon's Avatar
2008 TL AT 143,000 miles
This week I discovered a 12 inch long 3 inch wide wear strip on a front tire that had gone thru the first belt layer. I had bad shaking in the steering wheel as well. It turns out that the Left front outer tie rod end (TRE) had severe play in it. I can't understand why I had not identified it previously. The right side outer TRE and both inner TRE's are solid. I got a new Moog outer at a local Advance Auto/CarQuest and got it installed in under an hour.
I put a Sharpie dot in the very center of the old cap above the TRE ball joint and one on the new one. Before removing the old one I measured from the dot to the edge of the inner boot, exactly 23.6 cm. I installed the new one using that measurement. She drives and tracks exactly as new now. I felt like a genius.
I also put new rubber all around yesterday. It is smooth and accurate. Pure joy and satisfaction.. and pride.
Old Jun 30, 2018 | 08:20 PM
frankjnjr's Avatar
Hey algonquinloon, appreciate the diagnosis, and repair explanation. Good call on taking the measurements, so no need for alignment. Thanks
Old Jun 30, 2018 | 08:35 PM
Thanks man. I recall searching 'clunking' threads and don't recall seeing any mention of tie rod ends. I was sure it was related to the compliance bushing and was ready to buy a new lower control arm. Hopefully other members with clunks will not overlook the tie rod end as I had. It was ready to give way at any time I believe.
1st timer
Aug 10, 2011 05:48 PM
develop216
Aug 5, 2009 12:07 PM
EPS CL
1G CL Tires, Wheels, & Suspension
Jun 15, 2005 04:58 PM
CL SLeePeR
Jul 23, 2004 03:02 PM
donduncan
Jun 23, 2004 05:16 PM
