Foglight mod!!
Old Oct 13, 2011 | 10:30 AM
Project_CLean's Avatar
MMkay.
Foglight mod!!
Does anyone know if there is a way to bypass the foglight only able to be turned on when the headlights are on? on an 04 TL meaning the fogs are in the headlights.and the switch is the same as the turn signal switch (combination switch)..there was a way on my lexus; you add a circuit to the ignition fuse and wire it to the fog light relay- so one the ignition is on; i can turn the switch off or on as i please..if anyone could point me in the right direction.itd be much appreciated
Old Oct 13, 2011 | 03:22 PM
callahan's Avatar
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-independent-fog-lights-stock-switch-772633/
Old Oct 14, 2011 | 10:26 AM
MMkay.
damn;thanks a lot!
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
lanechanger
Oct 13, 2015 10:56 AM
