Fog problems
Old Aug 20, 2014 | 03:08 PM
.TODD's Avatar
Fog problems
so I tried to do the independent fogs and it didn't work can someone help?
according to the instructions I seen you have to cut the blue white off the combination switch behind the wiper switch I ran a piece of speaker wire from there the switch side to the fog relay. cut the blue black wire connected it to the relay side and nothing. no fogs everything else but no fogs? if I put the test light on the bare connections than the fogs come on independently as desired with the switch?
can someone help?
Old Aug 20, 2014 | 03:57 PM
Vlad_Type_S's Avatar
Registered Bike Offender
07-08 TL?
I can definitely help. You sure you connected to the switch side of the BLU/WHT and not the harness side?
Also, you sure you connected the BLU/BLK on the harness side?
You can test normal function by grounding the BLU/BLK wire. If the fogs turn on, then you'll know the problem is on the combination switch side.
Old Aug 21, 2014 | 08:12 AM
.TODD's Avatar
Originally Posted by Vlad_Type_S
07-08 TL?
thanks I will reattempt this weekend
Old Aug 24, 2014 | 01:42 PM
.TODD's Avatar
07-08 TL?
switch side blu/whi
black blue on the relay
Old Aug 24, 2014 | 07:12 PM
CubanLynx84's Avatar
under renovations....
First fix is to get rid of using speaker wire!
Old Aug 24, 2014 | 07:43 PM
erg69's Avatar
^^ Gulp......
Old Aug 24, 2014 | 08:40 PM
UTAH TSX's Avatar
I did the same thing you don't hook it to the switch side of the blue white wire you hook it to the other blue white wire in your first picture
Old Aug 25, 2014 | 07:43 AM
.TODD's Avatar
that fixed it Utah thanks!
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
