Flat, broken CV, and ejected spark plug
Old Oct 27, 2012 | 09:36 AM
  #41
nfnsquared's Avatar
Originally Posted by Esanchez8701
oh yes im sorry man my head is a bit clouded im still pondering on how it happened. I torqued it with one full turn and then a half a turn i believe thats correct right ? No anti seize was used. Ok now that we got that out of the way seems that the plug bursted but its possible it wasnt torqued right so maybe it was loose.
I read earlier in this thread that if you hear a ticking sound or clicking sound coming from the engine then its most likely that one of the plugs could be loose. Is that what you call a misfire ?
Can't be sure until the cylinder/plug has been checked, but sure sounds like the plug came loose and blew out. You may get lucky and only be out the cost of a coil pack and plug.
And I'd go back and redo all of your plugs using anti-seize and 13 ft-lbs per the service manual specs. If you choose not to use anti-seize, then I'd probably follow NKG spec (18 ft-lbs). Don't rely on "feel" to tighten the plugs. Lesson learned probably....
Old Oct 30, 2012 | 06:54 AM
  #42
NEWireless's Avatar
There is no pressure on the coil. It sits on top of the spark plug. Sounds like the plug blew out. Question is why?
And I asked about proper torque on the spark plug, not gap. And whether or not you used anti-seize on the plug threads per the service manual procedure.
I had an engine misfire code right before my plug blew out. So I suspect the plug was loose despite my tech saying that he always torques to mfg spec.
Old Oct 30, 2012 | 03:59 PM
  #43
nfnsquared's Avatar
But the question is: Which mfg spec did he use? Acura or NKG?
Old Oct 31, 2012 | 01:32 PM
  #44
NEWireless's Avatar
He said he always uses engine manufacturer torque spec because warranties are on engines not plugs.
Old Oct 31, 2012 | 01:37 PM
  #45
nfnsquared's Avatar
So he used 13 ft-lbs?? Did he use anti-seize on the plug threads?
Old Nov 5, 2012 | 09:44 AM
  #46
NEWireless's Avatar
Unknown
Old Nov 5, 2012 | 09:47 AM
  #47
nfnsquared's Avatar
Unknown
He probably used the acura spec (13 ft-lbs), but didn't use anti-seize....
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
