Fixing rust behind rear wheels
Hey,
I've got an 08 TL Type S (NBP) that has a rust spot behind each rear wheel. I'm trying to take care of it (correctly) before it spreads/completely eats through the metal. Given that the paint is mostly intact, but bubbling, I have to assume the metal is rusting from the back of the panel.
How much stuff needs to be disassembled to get behind there? Nothing, wheel well liner, rear bumper, etc?
Any tips on fixing it? I was planning to use a wire wheel to knock off most of the rust, put some naval jelly on there to clean up remaining rust, spray it with some "rust converter" (to fix any that I still didn't get), then encapsulate it with Rust Bullet. Then use some fiberglass bondo to fill/sand smooth, and then touch up the paint with NBP paint.
Is there anything (that looks good) that covers that area? I'm thinking of getting the A-Spec kit... does that go up higher than the standard bumper to cover the area, so I could fix the rust, but not need to worry about getting it looking perfect?
Thanks,
Pat
Thanks,
Pat
A spec doesn't go higher than the bumper
Doh... I figured I wouldn't be that lucky.
Heh, crappy picture. The brown is just a reflection of the edge of my driveway. The bubbling just above the plastic bumper is what I'm worried about. I circled it in this pic. I have a matching spot on the other side as well. :-/
Thanks,
Pat
Thanks,
Pat
Mine started as well recently. It hasn't started to bubble yet, but you can see a little bit of brown where the body and bumper meet. Took it to body shop and he said it's not worth fixing. Put some WD-40 on it every so often and it won't spread. This guy has a HUGE business and is successful. I trust him.
WD 40 huh...
Heh, the WD40 is an interesting idea. Like I said in my first post, I plan to take care of it the right way (or at least how I think is right)... I agree that it's not worth $500 or so to fix. While I really like the car, it's my daily driver, and it's got other imperfections. The rust spots, or my (possibly poor) attempt at fixing it isn't going to make or break the looks of the car. I really don't want it to spread or eat all the way through though.
I guess I was really just looking for tips on what needs to come off to access the area, and the possibility of covering up my work with a body kit or something.
Pat
Pat
Hey,
Thanks,
Pat
Thanks,
Pat
Last edited by frankjnjr; 10-12-2017 at 05:21 AM. Reason: aft looking at the pic closely, it appears this could be surface rust only, difficult to tell/
You need to sand it down to bare metal at the issue spot and any surrounding areas. I would then treat/seal it with some sort of rust inhibitor (turns the affected areas black), then prime, and add body filler as needed to level it out. Then paint/clear/wet sand. I had something similar on the front side of the passenger rear wheel where it meets the side skirt. It's tedious and takes patience but a doable DIY job. Since my car, at the time, was already 8 years old, I wasn't too OCD about coming out perfect. There's imperfections for sure, but it was my first time doing any sort of body work so I'm happy with the results for about $50 in supplies and a few hours of my time.
