Few issues with '04 TL
Old 08-31-2012 | 10:56 PM
f.tardif's Avatar
just bought and 04' TL automatic with 156 000 miles (i know there's alot but bought it cheap and didn't really thought about it). even thoe, so here's the fiew issues i have. i searched the forum for some answers but...
1- there's a warning in the dash that says my windshield washer liquid is low but the tank is full.
2- on the 3th gear, the car often vibrates. so i've changed the tranny oil (with dealer oil) and it's less wors but still, it sometimes vibrates. other than that, the car shifts smooth.
3- and just now, the little green light in the dash that says in wich gear you are (R,D,N, etc.) just started to flash...
4- and is there a frequent problem with some prestone leaking from the hose that goes to the heating radiator cause there seems to be a leak from there...
thanks guys. hope i'll have fun with this car cause i putted some money in some fixes that i didn't knew the car had when i bought it (my mistake that i didn't make an inspection)
Old 09-02-2012 | 06:28 AM
GeeteeDan's Avatar
I Like turtles
1. Probably a sensor bad
2. Replace the 3rd and 4th gear pressure switch
Old 09-04-2012 | 03:09 PM
Guiltyox's Avatar
1. Like Geetee said, probably sensor.
2. Like he said again, try replacing the 3rd/4th pressure switches (DIY tutorial available upon quick search).
3. This is a known issue for automatics and I'm not quite sure what it is, since both my old '04 TL and my '08 TL-S were/are MT. Though I've definitely read literature on it, so I'd try searching (it may even be related to number 2).
4. Replace the hoses and fasteners, could be old and dry-rotted (the hose), and the fasteners could just be tired (not holding well). This is a quick fix and shouldn't cost you more than like 20-30 bucks.
Old 09-06-2012 | 07:35 PM
f.tardif's Avatar
cool thanks. already had read about that gear pressure switch issue but just wanted to confirm.
where can i get those switch and what average price? i've searched on rockauto and couldn't find them...are they complicated to change?
Old 09-06-2012 | 08:39 PM
GeeteeDan's Avatar
I Like turtles
dont worry about rockauto, go to oemacuraparts.com
it by far will be the cheapest place. The DIY thread has all the part numbers for the switches. I did mine 2 months ago and its not hard at all.
Old 09-07-2012 | 07:38 AM
nismopowerdqg's Avatar
LowNslowTL
im in the same boat as you man, i bought mine used to dd around town and it has 162,000 miles.. runs great but the trans is shuttering. :/
Old 09-07-2012 | 09:34 AM
f.tardif's Avatar
thanks guys for the quick reply. will do the search and make the repair. will keep it posted.
Old 09-29-2012 | 04:33 PM
f.tardif's Avatar
changed the 3th n' 4th gear pressure switch plus did a 3x3 tranny drain fluid. WOW, amazing. felt the difference IMMEDIATLY. with the DIY's, the work was done in no time.
juste have a little question to be sure for the 3x3 i did. so when i buy a 12qts of tranny fluid, at the end, there's not suppose to be any full bottles right? basically, you drain 3x the fluid, and have to add 4x the fluid??
even thoe, i recommend this to everybody. it costed me 200$ for all the necessary for this, made the work by myself, took a couple of hours (the longest was to change the tranny fluid as you need to jack and unjack 4x times). it resovled my vibration issue and the tranny shifts smooth as a new car.
Old 09-29-2012 | 05:46 PM
pohljm's Avatar
3x3 = 9, not 12! only need 9 quarts total. save the other 3 for a swap about 2 oil changes from now!
Old 09-29-2012 | 11:08 PM
subinf's Avatar
One on the right for me
We have a sensor for the washer fluid?
Old 10-01-2012 | 05:24 PM
f.tardif's Avatar
damn....used the 12 of them...even thoe, the oil can't be cleaner than that.
Old 10-02-2012 | 09:02 AM
01blkgts's Avatar
glad to hear you got the shuttering fixed
snorf
11-04-2019 06:44 AM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
Frathora
09-28-2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
09-22-2015 11:40 PM
carz0159
09-20-2015 06:11 PM
Quick Reply: Few issues with '04 TL
