F'd up the dome light
8th Gear
![Thumbs down](https://acurazine.com/forums/images/icons/icon13.gif)
New TL owner here, so of course 1st thing I did was order some hyperwhite LED's for the interior (with the help of the LED thread).
When I got to the dome light, the 2nd bulb crushed in my hand.
Shattered into pieces, only the wedge part is still in there. I remember reading through one of the threads same thing happened to somebody and he had to take it in to the dealership.
I'm pretty much SOL and gotta do the same yeah?
1 Post
^+1. yup same thing happened to me when i was doing this mod. keep messing with it with really long needle nose pliers and i may have even used a small flat head screw driver...long story short i eventually got it out so no you dont have to take it to the dealer. when your doing the others just slowly wiggle them back and forth, eventually they will come out, good luck
University of Tennessee
Use some clear tape on the other ones. Use enough that the tape comes around to make a grip that you can use to pull it out. But yeah, use pliers on the one stuck in there.
8th Gear
The needle nose pliers was my first reaction, but it seemed like the deeper I would try to dig in to take it out the more of the glass would break, since the wedge is glass as well. I didn't mess with it too much though, so I will give it another shot tomorrow. Thanks guys.
old school full-size light bulb trick was using a potato...maybe use a half-thawed steak fry or something. or a pink eraser bar? good luck getting it out tho for real
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I would definitely recommend this method to anyone changing the dome lights. I got both mine out in couple minutes.
8th Gear
So the only thing I was able to accomplish with the pliers was break the rest of the glass that was in there, except for a tiny piece. The metal rods are still in there.
At this point I could probably just stick the new bulb in there. Would that be safe with the remainder of the old rods still in there?
04Tl
Yea same thing happen to me then i used tape on the rest of the bulbs and they came out really easy. What i did for the the stuck bulb that got crushed was i took some needle nose pliers and plucked it right out but then in the process i saw a spark and all the lights went out lmao . but all i had to do was replace the fuse lmao. Def. dont take it to the dealer.
8th Gear
It's hard to get in there with the long pliers, can't really get in there like that to grab the metal out. I went to home depot to see if they had any thinner pliers, but mine are actually thinner than anything they had in there.
It's dark out again so I'll give it another shot tomorrow but I don't have much hope
![Newbie](https://acurazine.com/forums/images/smilies/newbie.gif)
you can take out the whole housing there and work on it inside. i suggest doing that. I did the same thing, broke the bulb but luckily my local mechanic was nice enough to sit down and get it out for me.
8th Gear
so I said fuck it, grabbed my flashlight and went on a mission.
but I got it out. I pried one of the metal pieces with a flathead and was able to pull it out with the pliers. But it did indeed feel like a surgery, cause I knew that if the metal broke off I woulda been fucked at that point.
Thanks for the support... My Rvinyls came in, I will let you guys know how I mess those up
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
