Engine shaking & Missfire
#41
We did perform a leakdown test on cyl. #4,5 &6 (front head) and have buble coming from the radiator cap when we did the leak down on the #5 so it's a bad head gasket, For the rear head i will bring my car to a shop specialize to do that kind of job and they will check there. The tech today tell me one spark plug have oil on it so also the valve cover gasket is bad!! Wow, right now i'm not sure if i will do the head gasket if the rest of the car is ok... If you see the car you can't imagine the car was not maintaint properly, the body is in perfect shape the interior and under the hood also :S
#42
And oil on the spark plug could just mean the plug was loose and/or the spark plug seal was bad. My guess is a loose plug. I doubt it's due to a bad VC gasket.
#43
Dogmatic Dinosaur
I will assume that he meant the top part of the plug.
You have to take all of that off to take the head off, so don't let 'em charge you too much more than parts on the valve cover gasket.
#44
Dogmatic Dinosaur
OP, it's not your IM gasket....I've had the IM off and there's nothing there....I suppose a massively leaking head gasket could theoretically allow coolant to flow across to the IM gasket, but I'm not buying that...you'd have steam under the hood and would be able to smell the coolant...
i
![](http://i263.photobucket.com/albums/ii154/jmillerl/intakemanifolddiagram.jpg)
i
#45
Oil on the top of the plug is valvecover, on the electrodes could be heagaskets to bad rings.
#46
Does that "gasket - replace" go to a runner, or are those parts part of the head? I guess that if those are just runners, then there are other gaskets elsewhere. I am just curious - I have never had the heads off of my Acuras. I cannot find a head picture on the net, but the gasket kit appears that it comes with another gasket for the lower part of what looks like an intake manifold.
#48
I'm not real clear what you meant by not sure if you will do the head gasket. You have to, besides other reasons, it can fire cut the head and block and then you're basically looking at a new engine. At least you know the problem.
#49
Somebody is able to find a picture of what both heads look like. Like the picture of the Im and all gasket and bolt?? I know some of you have more ressource than me! Thank you for your help guys!
#50
![](http://i263.photobucket.com/albums/ii154/jmillerl/intakerunners.jpg)
#51
#52
Dogmatic Dinosaur
Thanks guys. I thought that I needed to know for some reason so that we can suggestion checking both gaskets in the future.
Acadien - you don't know yet if it is a gasket or cracked head. A good mechanic will know when they take it apart. No chance that the ecu is causing combustion chamber gases to get into the radiator... so don't sweat that. This is why you need a good "tech" or mechanic - I don't even know how good they have to be since I am just a weekend mechanic on my own cars (and my friends) and I can tell the difference... but my mistrust of most dealer "tech" is pretty high.
It is probalby the gasket, but it could be the heads if the engine ever got hot. Do you remember the readings on the "good" cylinders?
#54
![](http://i263.photobucket.com/albums/ii154/jmillerl/injectorbases.jpg)
OP, here's the best pic I have of the front head with VC removed (IM gasket is still in place over the injector bases):
![](http://i263.photobucket.com/albums/ii154/jmillerl/valveadjustmentpicture.jpg)
#55
Hi, just a quick question. On the labor guide book it's said 13.5 hrs in labor to do both headgasket, It's more time than what i think! Do you think It's gonna need that much?
My car is scheduled next tuesday to do the head gasket job... Hope it will resolve the problem!
#56
My car is scheduled next tuesday to do the head gasket job... Hope it will resolve the problem!![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
Which reminds me, make sure they check them for flatness. If they're warped and they don't surface them while they're off, you will just blow the new gaskets over time. If they surface them, find out how much they take off. I've seen some shops take a ton of metal off of warped heads trying to make them flat again when they should have been replaced. With the 11:1 compression ratio, there's not a whole lot of room for the extra compression.
Oil should be changed also. Speaking of oil, have you checked the crank case to make sure no coolant got in there? If there's any coolant in the oil, you need to drain it out, fill with fresh oil, start it for a minute and then shut it down until the work is done. Coolant can eat the lead in the rod and main bearings while the engine is off.
Don't be surprised if you get oxygen sensor codes in the future. Coolant in the exhaust and 02s don't go together.
As soon as the heads come off, it will be obvious the gaskets are blown.
#58
#59
#60
#61
The problem is the tech does not have the tools to determine if its warped. You can lay a straight edge on it to see if there's bad warping but just a few thousandths of an inch is enough to blow a head gasket. Its not a bad idea to get it surfaced and have them just barely touch the surface to give it a nice finish for the gasket to hold on to. Make sure the deck is checked for flatness. Not likely to be warped but they might as well check it.
#62
The SM calls for resurfacing if warpage is between 0.05 - 0.2mm.
I'd have it done regardless to ensure proper finish on the heads. If it's not included in the 13.5 hours, then you're only looking at an additional $75-$150 for both heads. Aluminum heads have a tighter spec for finish smoothness. Many shops recommend refinishing of aluminum heads anytime they are removed.
Make sure they (or whoever they send the heads to) use a profilometer to measure the finish.
P.S. Here's a better diagram of the heads with the attached injector bases:
![](http://i263.photobucket.com/albums/ii154/jmillerl/cylinderheaddiagram.jpg)
#64
Hey, Update for my car, this is really hard to find a head gasket kit for a Tl!! All Auto parts company around here not be able to find it in Canada! We did find a company in the u.s.a. did have there... From the dealer the gasket kit is around $1100 and from the u.s auto parts is $300!! I'm so happy we did find one! Only concern is i hope the gasket kit will be good quality, I know the one from the dealer is the best but $800 more is too much.
#65
Or acurapartswarehouse.com?
http://www.acurapartswarehouse.com/P...gPicture=False
Should run you about $275 US, plus shipping for an OEM gasket set (front and rear).
#67
#69
First, if the temp stays cool and the gauge doesnt reach like it normally does, in the middle. Then replace the thermostat censor, seriously its that simple. Second, I had the same problem in my car, the engine was jumping around like crazy, the rpm was so low that 500 would idle then it would shut off. So I go and check something out, my catalytic converters where old now so it needed replacement, the reason it was doing that with my engine, was because air goes in, but if you have bank 2 and underbody cat clogged, there is no clearance for whatever needs to go out, and when the inside of the catalytic converters breaks up, its a bunch of crazy dust. check all 3 of them and replace the o2 sensors if you replaced the catalytic conv. and inspect the other 2 and work from there. So after doing that, i was happy. No more engine shacking. Went home happy. Next morning I drive it and about 15-20 min in a red light starts doing the same thing and shuts off. I turned it back on and there it was again, the shacking with the low rpms but this time at 1000. went back to my buddies shop. I got the scanner and had misfire in 1,3,5. I pulled out the spark plugs they were all good, except for one. the spark plug from cylinder 1 had oil in it. I got kinda worried. Cleaned it, put all 6 new in, replaced the valve gasket cover and turn it on, it was good for like 20 min when this time smoke came out the exhaust. OMG i was freaking out. i then check out the coils, but i knew that was bad because, smoke out of the exhaust it was the oil being burned, so i kinda disconnected each coil, and 5 were good but cylin. 1 stayed the same, didn't shake a little like its supposed to. i checked my valves maybe they were tight, typically they do and we have to manually adjust them. I turned the car back on even more smoke. i wa flipping out. i was thinking a new engine. but nooo. cus i got another bud that works at the acura dealership, he was telling me that all i needed was to spend 200 dollars more. it was the Piston Ring 150 and the valve stem seals 28. after replacing that it has runned like new. it was the stem seals were old and letting oil in, after that being done it didnt shake no flashing engine light .
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
