Emission light on?
Old May 12, 2008 | 12:01 AM
idL*TL1R's Avatar
5th Gear
Emission light on?
My question is that the light on the "heater switch" went out on the driver seat , but the passenger side is working?
So ,I went to the fuse box to check if one of the fuses was out. Which I could not find the fuse for? But the problem now is that when I turned the car on I got the emission light on and the MPG and MPH I believed got reset because they went to zero's. I dont know if the problem happend when I was pulling a couple of fuses out or what. If anybody knows if the"heater switch" light has a fuse or something? and if anybody knows how to get that emission light to come off ???
Old May 12, 2008 | 12:03 AM
sixsixfour's Avatar
you may have accidentally pulled a wrong fuse. the fuse box cover should have a diagram.
Old May 12, 2008 | 12:11 AM
01tl4tl's Avatar
Is the seat heat working? or is it just the switch light?
Old May 12, 2008 | 12:20 AM
idL*TL1R's Avatar
5th Gear
I believe the seat heat is working, is just the courtesy light that reads Hi and Low that does not light up? The little yellow lights when you press the hi and low do turn on though?
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Sep 17, 2015 09:01 PM
Sep 17, 2015 10:16 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
