Emergency
Old Dec 14, 2010 | 12:20 AM
RIGA's Avatar
Emergency
I rolled down my window to yell at my friend and now my window will now come back up....It is currently 7 degrees out....Help!
Old Dec 14, 2010 | 12:43 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
You might have to take the interior door liner out to take a look at the window guide. Hopefully you won't need a new regulator. Does it make any noise when you try to roll the window up?
Old Dec 14, 2010 | 01:50 AM
RIGA's Avatar
Ya, goes up about 2 inches, then clicks and goes back down
Old Dec 14, 2010 | 01:58 AM
libert69's Avatar
18psi
try pulling it up with your hand when it goes up those 2 inches and guide it back up
Old Dec 14, 2010 | 02:03 AM
anthracite_ftw's Avatar
My passenger window did this last night, and it was 19 degrees out. Kind of ironic that this only seems to act up when it's cold out. Luckily I got it to go back up after playing with it for 5 minutes or so.
Old Dec 14, 2010 | 02:47 AM
mrlal8's Avatar
this shit happens to me randomnly ONLY on the passenger side and usually when its cold. When u just pull the window switch for auto roll up it will go back down. What u usually do is try the auto rollup 3 times and then hold the switch up until the window finally goes up....ya ghetto
Old Dec 14, 2010 | 06:59 AM
jsonkimz's Avatar
NOT the definition of irony...
Yeah, I would try to guide it back up. Then DON'T roll it down again. I would avoid using the auto roll up as well until you get it fixed. Just try to get it to roll up without using the auto. Sometimes the auto has a mind of its own.
Old Dec 14, 2010 | 08:52 AM
TypeR?'s Avatar
i believe this is a common problem on the 3rd gen tl's(i know its happened to me at least twice) i dont remember the procedure but i believe it is in the owners manual. maybe someone else can chime in i know i have seen it on here before.
Old Dec 14, 2010 | 09:40 AM
LowLow06TLNH6's Avatar
06 White Diamond TL
Need to replace the window door glass run channel and or the window regulator....
Old Dec 14, 2010 | 10:23 AM
jda123's Avatar
Dogmatic Dinosaur
Will it go up if you just pull the switch up one notch and not to auto? Mine sometimes fail on auto, but always work on manual. Once it gets about half of the way up, you should be able to use auto then.
Mine only act up when cold too.
Old Dec 14, 2010 | 11:08 AM
06 White Diamond TL
Spray some silicone spray on the run channels and clean the glass, might work till you replace parts..
Old Dec 14, 2010 | 11:25 AM
nfnsquared's Avatar
My Dad always told me, "Nothing good happens after midnight". Stop yelling at your friends and get home early
Whoa! Not so fast. OP, read this threadi. You may just need to clean things, and the dealer may cover you via the TSB:
https://acurazine.com/forums/3g-tl-problems-fixes-114/window-strange-problem-help-749540/
OK, that's better
Old Dec 14, 2010 | 01:13 PM
RIGA's Avatar
I got it to go up by manually guiding it up. Haha Square, I was leaving a final exam and I was asking him if he needed a ride home instead of walking when its brutally cold
Old Dec 14, 2010 | 01:21 PM
rlspen's Avatar
4th Gear
Window off
Did you recently have the vehicle washed? Ice may have created the issue.
rockyboy
Aug 4, 2024 10:35 AM
steve
Sep 30, 2015 09:23 PM
kixo
Sep 25, 2015 03:07 PM
tndirtdauber
Sep 23, 2015 03:00 PM
