Electrical Flutter when Turning Ignition
Old Oct 13, 2008 | 07:34 PM
judgecj's Avatar
Unusual problem has happened about four times now...
2004 TL 5-AT, Navi
Unlock the car with the key fob, put the key in the ignition, and... the doors lock and try to relock, the dash lights flicker on and off, and the car generally seems to struggle to start. Tapping the gas usually turns over the engine, or else I have to turn the ignition back to stop, then turn key the key to start. Usually works on the second turn/try.
Any ideas what's going on here? The car is entirely original except for a replacement battery about 6 months ago.
Thanks in advance for the suggestions and assistance.
Old Oct 13, 2008 | 07:38 PM
BLACKURA_NY's Avatar
I have car ADD
is the replacement battery OEM ? if so... JUNK IT !!!! people have had OEM batteries die on their 08 models.... mine is still good, but i know the OEM is crap
could also be alternator or starter issues... but my money says its the battery
Old Oct 13, 2008 | 07:50 PM
ecliptics's Avatar
steeez
new battery
Old Oct 13, 2008 | 07:51 PM
judgecj's Avatar
Not an OEM battery, and I was unfortunately in a pinch and I think the replacement came from AutoZone.
Old Oct 13, 2008 | 07:57 PM
ecliptics's Avatar
steeez
i think you answered your own question the autozone battery might be a dud.. most batterys come with a warranty though like a year or somthing. dying 6months into it is def premature. if you have the receipt go back and get a new one, or maybe use that credit to get a higher end one.
Old Oct 13, 2008 | 07:59 PM
judgecj's Avatar
Thanks. I'll give that a shot first. So not the alternator or anything more serious?
Old Oct 13, 2008 | 08:05 PM
ecliptics's Avatar
steeez
well it could be, but most of the problems you described are eletrical like the lights fluttering, def sign of a bad battery. if the problem persist then have acura pop your hood
Old Oct 13, 2008 | 08:06 PM
playa4real's Avatar
def. the battery
Old Oct 13, 2008 | 08:11 PM
judgecj's Avatar
Originally Posted by playa4real
def. the battery
Ok. Thanks to each of you that replied. Any suggestions on what kind of battery? Thanks.
Old Oct 13, 2008 | 09:31 PM
I have car ADD
Optima is always good.. so is Braille... not sure what else...
i think the Red-top is what you'd need.. .yellow top is for big audio systems
Old Oct 13, 2008 | 11:11 PM
Dima1978's Avatar
Costco Kirkland. Costco has Optima red as well(yellow on a stock car is a little too pimping ). PS What was that HFL TSB for. Wasn't there a bad drain because of faulty HFL unit? I am having the same problem, 480 Cranking amps left on the OEM battery. i have noticed with Costco they don't put their name on crap. IMO :-)
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
pistacio
Sep 26, 2015 09:45 AM
Sep 17, 2015 10:16 AM
CadiGTi
Sep 14, 2015 06:37 PM
