Ecu Reset? Anyone?
Old Nov 14, 2005 | 11:20 PM
Abbass Hassani's Avatar
Ecu Reset? Anyone?
Hi guys I feel that my car is not as responsive as it used to be when I had first got it, and I was wondering if anyone knew how I could reset my ECU...I understand that unhooking the battery won't do the job as it has its own internal battery...
Anyone?
Old Nov 22, 2005 | 12:14 AM
how mean!!!
Old Nov 22, 2005 | 02:05 AM
acura101west's Avatar
easy disconnect the battery(cables have to be disconnected from battery first) and touch the postive cable to the neg cable to drain the rest of the joose in the cables and reconnect,you will have to reset everything
Old Nov 22, 2005 | 05:46 AM
JDM5lugHatch's Avatar
Now with i-Vtec
I have always done the following to reset the ECU.
1. Disconnect the - Negative Battery Cable
2. Allow the car to sit at least 30-45 mins. (I usually just do it in the morning and come back to it whenever)
3. Reconnect - Negative Battery Cable
4. Start the car but don't touch anything at all. Just start it and let it run for 10 mins or so just enough for the ECU to learn the cold start, let it idle down and warm up.
5. Turn the car off and remove the key from the ignition.
6. Start the car again.
7. Drive it like you stole it.
8. ????
9. Profit
Old Nov 22, 2005 | 08:06 AM
Brettg's Avatar
And why would anyone think resetting the ecu would fix a problem?
Cars with the automatic transmission are supposed to learn the driving habits they say, I am not sure if you can actualy feel the difference or not.
I would suspect other things like low tire pressure, bad gas (many stations put regular in all the tanks), winter formulated gas, dirty air filter (one person found a plastic bag in the filter box, I had a big leaf), etc.
Brett
Old Nov 22, 2005 | 10:41 AM
Pure Adrenaline's Avatar
Dragging knees in
8. ????
9. Profit
Old Nov 23, 2005 | 12:28 AM
the reason you touch and hold the cables together is so you dont have to wait 30 to 45 mins
we do it all the time to rest navis at the dealer
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
