E-Brake Question
Old Aug 15, 2007 | 04:08 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
E-Brake Question
I have a '07 TL Type-S, and something happens everytime I engage my e-brake. Whenever I engage it, it "gives" a little before fully stopping. For instance, if I park on an incline, the car will move back an inch or two before coming to a stop. The same is true if I park on a decline. I know that in steep grades, the brakes are bound to give some, but I'm talking about normal everyday situations, where it doesn't matter how hard I engage the e-brake, it still moves before stopping. This is true even if I leave my car in-gear when I park. It didn't seem normal to me, and I recently got my "A2" service done, and they adjusted the e-brake during that service. I thought that would take care of the problem, but it still exists. It gets on my nerves, but it's something I can live with. Has anyone had this issue before? Any thoughts?
Old Aug 15, 2007 | 07:57 PM
NBP07type_s10's Avatar
I have an 07 Type-S and noticed the same thing. When I first got the car it drove me nuts because every other car I have owned the car didn't drift when I applied the parking brake. I think this is just normal for this car.
There have been a couple of forums on this topic and others seem to experience the same thing. I was concerned that my parking brake wasn't working but when I set the brake and then put the car in neutral on an incline or decline, the brake holds the car.
I've had my TL-S since January and have gotten used to it working this way and never got it adjusted at the dealership.
Old Aug 15, 2007 | 08:29 PM
01tl4tl's Avatar
They are just little drum brakes inside the rear rotors
Apply first- then park in gear
Learn to curb your wheels
If the dealer touched it and its not right- back it goes!
Old Dec 28, 2007 | 04:23 AM
stavebomb's Avatar
im pretty sure thats not "normal" my E brake used to be really nice and would hold sturdy but after a while it became loose. During one of my services the even tensioned it up. I know how they did it, but its back loose again. If anybody knows how to tighten it back up please let me know cuz i dont feel like going to the dealership again...
Old Dec 28, 2007 | 10:00 AM
vinnier6's Avatar
leave the car in neutral aply the park brake and let it settle in, then shift it into park...thats what i do so that the car isnt sitting on its transmission....
Old Dec 28, 2007 | 01:11 PM
01tl4tl's Avatar
good advice vin- that saves the trans from getting stuck loaded-weighted in a gear- especially automatics.
Back to the old story- the park brakes are tiny drum brakes housed inside the rear rotor.
You adjust them via a star wheel- accessed via rubber plug on center of rotor. Old School.
The trick is, to do it correctly- you need to remove the caliper and brake pads- turn the rotor and listen for contact, then x amount of clicks tighten from there
Its easy to wear the ~shoes~ out if brake left on and pulled out of the driveway numerous times
I dont know how the dealer adjust them at service, newer cars and manual trans often have an adjuster next to the park brake handle if its center console mounted- push the rubber aside and look there
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
