Driver's side mirror intermittently moves on it's own
Hey AZ, In the past couple month's, my driver side mirror will randomly move on its own and start clicking while I am driving. I will then have to open the window and push the mirror into place with my hand. I did a search and found a similar thread to my problem and somebody mentioned that there is a "switch" for the mirror that might be bad. I tried searching for any type of mirror switch on Delray's site and I can't find anything. Also, my memory seat control unit hasn't been working for the last year or so. Could the problem be with that unit also?
Oh, my car is a 2004 base.
Holmz20 (06-18-2012)
MMkay.
hey man; I'll be glad to help if you could just help me out with a little more information? Have you noticed any other things that don't work? Windshield washer and Auto Dimming mirror? You stated your mirrors do not hold memory? as well as the seats dont either? but they do still work correct? you can control and move them from the switches?
RyanCHICL (01-25-2012)
MMkay.
Service Bulletin 04-005 explains the issue with a bad MSC unit. The part itself isn't too bad at $143; if you or a local shop can do the job for you.
I do not think this problem is causing the issue with your mirror; as the actuator has it's own seperate bulletin as well: 09-047.
Let me know if i can help any more; let us know what you do to fix please.
The following 2 users liked this post by Project_CLean:
michaelap95 (02-28-2015),
ok problem with memorie seats could be as simple as your remote is not programmed to your car it will still lock and unlock but it will not beep when you lock it,when you unlock it and open the drivers door on the cluster it should say somthing like driver 1 detected or driver 2 detected if it does not refer to your owners manual for directions on how to program the remote correctly to your car then put seat where you want it and follow manual and save it with the memorie seat buttons..Also if you had a dead battery or had it changed that could of caused this issue..
..Hope this helps...
...I LOVE MY TL...
...I LOVE MY TL...
Ryan, what ended up being the deal with the memory seats? I've read in other postings that if the actuator is not working properly and the mirrors aren't lining up, it causes the memory seat function to deactivate (some safety reason). Did fixing the actuator fix everything? Note: I already read the post on these mirror conditions and the power washer motor going out...I replace the fuse with a 10A. But right now my washers ARE working, the power seats DO work...but the memory lights DO NOT AND the passenger side view mirror clicks for a few seconds even when parked. Could be the single digit weather too.
I am having a similar issue, check out my thread, it may help you out as well.
https://acurazine.com/forums/3g-tl-problems-fixes-114/07-tl-power-mirror-memory-seat-issues-904755/
I had this issue after having my mirror replaced completely (got side swiped and had to get a new one). My mirror kept moving all the way to the left everytime I started my car and I couldn't figure it out.
Turns out that it's a memory seat issue. I reset my driver 1 memory button and now the mirror doesn't automatically move when I start. Well, fingers crossed since I've only tested it once so far.
Hope this helps and reconfirms that it's a simple fix for those who are also experiencing this.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
