Driver Side Parking Light Issue
Old May 15, 2008 | 02:36 PM
AcuraATLBoi's Avatar
No Limitz!
Question Driver Side Parking Light Issue
My driver side parking light only works when I use the turn signal. When i turn the parking lights on, just the passenger side glows. this happens also when i lock the doors and the typical "beep" occurs. What could be the issue?
Old May 15, 2008 | 02:44 PM
1StGenCL's Avatar
958 & 991
Thats funny i just realized i have the same problem on the passenger's side. The bulbs are 7443 i believe and are dual filament meaning that there are kind of two bulbs in one if I am not mistaken. The bulb needs to be replaced because one of the filaments is out
Old May 15, 2008 | 02:48 PM
No Limitz!
Thanks so much
Old May 15, 2008 | 02:51 PM
No Limitz!
Can i get the bulb from like Pep Boys or somewhere?
Old May 15, 2008 | 03:00 PM
01tl4tl's Avatar
yes- they can look up the correct number at local parts stores- no doubt a special bulb like all the others!
Check the owner book for sure on gen3, on gen 2 you turn the steering to give room for a hand to fit in past the wheel and swap the bulbs- requires undo a few tabs that hold panel in place- pull panel back and there it is
BUT check your owner manual- cant find your book??- here is the free download- or view online- they dont actually make you download it!!=click your year then model
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
it will also have a section with all the bulb numbers
Old May 15, 2008 | 04:52 PM
No Limitz!
thanks. Completely helpful! What does the bulb usually run in price?
Old May 21, 2008 | 03:41 PM
ccoffe's Avatar
Smile you are the best
csmeance
Jan 7, 2026 06:25 PM
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
