Driver Side Electrical is screwy
Hi Guys,
I'm not sure if this is a fuse issue... Here are my symptoms
1) Seat Memory Does not work, does not even light up
2) Both power mirrors will not go up or to the left, I can move them down and to the right.
3) Rearview Mirror is not auto dimming
4) When I press to lock the doors all doors but driver side lock, the stem in the door does not move. I can press it down and all the doors including the driver side locks. This one started about a week after the three above, not sure if they are related.
Do you guys think it is a fuse issue? Any idea which fuse it would be?
Thanks for your help
1-3 are related there is a service bulletin. They put too small of a fuse in. you will have have a blown 7.5amp fuse it get replaced with a 10amp fuse and replacement of the fuse label.
Your window washer is prob not spraying either. It's a fuse in your L/F kick panel
#4 sounds like bad lock actuator
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
