Driver seat memory "forgets" after 3 days
I use the driver 1 key fob and I have set the driver 1 memory. It will work with the key and if you push the memo 1 button and move the seat and mirrors. After 2 or 3 days though, the light on the memo button goes out and the system has forgotten the pre-set. This didn't really bug me until I had my car at the dealership and spent the entire ride home trying to re-adjust everything after a particularly short technician moved the seats.
If I use the key-fob the MID indicates driver 1 detected but the memory is gone. Anyone have this problem or know of a fix?
there is probably a defect with the memory module. On the other hand, an issue that may be causing this is a low battery. I suggest that you leave the car alone for 3 days and then check the voltage on the battery.
See this thread for TSB info https://acurazine.com/forums/showpos...18&postcount=6
Finally just had time to install this one as well. The TSB says to remove the entire seat, I was able to do it in 10min w/o removing the seat if you have small hands like me. I got the part cheaper than $108 you can order it online for $80. New part works great.
rockyboy
Aug 4, 2024 10:35 AM
