Double-lock beep not happening
Double-lock beep
I have notice that if I am driving some of my friends TL's and I do the double locking that their car beeps. I do the same on my TL and my car does not beep. I have been doing some research and no one has that problem. I try to look for fuses maybe one of them is not working and nothing.
Thank you for all your help.
well after playing with both hands no luck
I have cheked the settings and its set to beep when car is locked.
all doors are completly closed.
does any one know where the beep sound comes from, where is that siren located at.
Lock the car, after 30 seconds or so look at the red led next to the driver door lock plunger. If it is not flashing with the car locked then the car thinks something is open. The most likely cause would be the hood latch sensor because all other doors/trunk would show up in your display.
Make sure you don't have a faulty lock. My TL will beep if all the doors are LOCKED, OPPOSED TO ALL DOORS BEING CLOSED. My passenger side door won't lock with the Keyless Entry and I have to lock it manually before
I can hear the beep with the double lock.
HOPE THIS HELPS
HOPE THIS HELPS
SidhuSaaB
05-30-2020 12:40 AM
