Door replacement help
Old Sep 3, 2016 | 11:36 AM
Jeremy Richardson's Avatar
Okay so my doors are dented and I'm going to replace them its gonna be cheaper than fixing. But i need to know, to remove a door and add another will i need to prove panels to get to the electrical wiring so i can disconnect it? And also will keyless entry still unlock it or will it not cause the door is different?
Old Sep 3, 2016 | 02:43 PM
csmeance's Avatar
It depends on what type of door you buy.
If you buy the complete door assembly with glass, lock motor, window motor, etc all you have to do is disconnect the harness under the rubber tube (when you open the door and it connects to the car) and simply take the door off the hinges (or remove hinges).
If you buy just the door minus the motor, glass, etc you'll have to move it over.
It's not very complex, just a bunch of screws. It should take about 2 hours per door to move stuff over.
Old Sep 3, 2016 | 02:49 PM
Why you open another thread regarding same issue..
Old Sep 3, 2016 | 09:56 PM
First was about removing dent, this is about removing door. Guess you didn't read.
Old Sep 4, 2016 | 03:43 AM
It segued very well .
Old Sep 4, 2016 | 08:52 AM
Midnight Mystery's Avatar
Null and proud of it
Whatever you do, make sure to ha d the door by yourself!!!
No, seriously, if the new door doesn't come with any of the elections, panels, window, just swap it all over accordingly...
Also, make sure to get a door from the same model year, given you can, or at least do your to make sure they match...
Best of luck!!!
And get help to hang the door properly...
Old Sep 4, 2016 | 07:17 PM
csmeance's Avatar
Please PM me a good email address for you so I can send you some help via a PDF!
Old Sep 13, 2016 | 08:24 AM
fek's Avatar
fek
7th Gear
Please post that PDF for the door! I need help too.
Old Sep 22, 2016 | 02:27 PM
He never sent it to me
Old Sep 22, 2016 | 03:21 PM
BreezyTL's Avatar
Do a search with acurazine in it. I am sure something will turn up!
