Does driver side footwell supposed to be lit???
2007 NBP TL Type S
if only the passanger side footwell light lit, than you might have a burned out bulb. check to make sure all the wires are connected. I don't know what kind of bulb it takes. I know on mine, both of mine are lit up. it might just be a burned out bulb. hope that helps you out
the 2007-2008 TL Base has blue lighting in the footwells. The TL-S has red lighting. It is common for tech's to forget to plug this in after doing any work involving the removal of the knee panel/lower panel when they reinstall it. A trip to the dealer can solve this pretty easily if that is the case. If the light is burned out, it's a simple replacement of snapping out the LED base and popping in a new one into the panel.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
