DIY - Changing flimsy interior door handle rod
so i picked up my car and didnt realize until i got home that my rear pass ddor did not open from inside. i originally thought it was the child lock but after taking off the door panel, i realized it was the plastic piece on the rod that was broken.
![](http://i5.photobucket.com/albums/y164/boricuacvc/05%20Acura%20TL/IMG-20110310-00246.jpg)
so i bought the part from acuraoemparts.com. the rear pass is part #72631-sep-a01
took the door panel off and removed door liner
![](http://i5.photobucket.com/albums/y164/boricuacvc/05%20Acura%20TL/IMG-20110310-00243.jpg)
unplug 2 harnesses, remove total of 3 screws come off from side of the door, they hold the assembly in place, one 10mm gold bolt towards the bottom, and 1 small screw on top that holds the door latch, and the whole assembly comes off
![](http://i5.photobucket.com/albums/y164/boricuacvc/05%20Acura%20TL/IMG-20110310-00244.jpg)
![](http://i5.photobucket.com/albums/y164/boricuacvc/05%20Acura%20TL/IMG-20110310-00245.jpg)
replace parts, reinstall. everything works!
exlex (01-17-2012)
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Ok, instead of creating another thread I figured I would just post here...
I'm trying to replace my rods broke both on my rear doors!), but I can't seem to get these brackets out. I removed all 3 screws on the side (thank you, impact driver!) and the screw near the top. I don't see a gold nut to remove, but I did remove a silver nut that attaches to the window channel. There appears to be some sort of bracket on the inside that's holding in the assembly. See here (apologies for size. Pic is horizontal):
![](https://dl.dropbox.com/u/5291479/20120129_173831.jpg)
And here it's the state the assembly is in.
https://www.youtube.com/watch?v=jWx6hGW8hRQ
Please help!
Please help!
Never mind, answered my own question after re-reading Acuratech2009's post. Just pop of the top part of the bracket (last picture) with a flathead. Once I did this I was able to worm the assembly out and swap out the actuator handle cable and re-install everything.
Just posting here to vent...
I HATE EVERYTHING ABOUT THE GREEN CLIPS AND THOSE CONNECTIVE BRACKETS. Spent way too much time dealing with both today as I worked on my sound deadening project.
If anyone knows how to take off the door panel without breaking these clips or has any advice about how to pop off that bracket a little easier, please post here. I'm 0 for 3!
the overexplainer
i took my front pass door panel off twice without breaking the clip..just dont let the door panel drop once you lift it over the door lock nub and gently pull the green clip out.
squeezed some insulating foam in different places to get rid of this annoying rattle.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Cuss](https://acurazine.com/forums/images/smilies/cuss.gif)
In related news, I replaced my outer door handle extension (the one that pops off for a lot of people). Was pretty easy to replace once I had the panel off and vinyl removed.
rockyboy
12-06-2022 02:29 PM
tman570
06-11-2019 07:56 AM
