DIY A-105: Power Steering Whine fix
Old 11-23-2014, 10:32 AM
  #681
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
That's awesome Red! Hopefully you don't need a new pump.
PS, I'll need this soon as my new reservoir should be arriving along with 2 new bottles of le fluid.
Care to share why you need a new res..
Old 11-23-2014, 12:00 PM
  #682
Red89gt's Avatar
I just hosed out my reservoir with brake clean, like brand new.
Thanks for the original post and help Majofo.
Old 11-23-2014, 12:17 PM
  #683
Majofo's Avatar
RS forgot / neglected to make sure his res was properly secured after removing it from the post. His serp belt cut a nasty gash into it.
Learn from his mistakes kiddos..
Old 01-02-2015, 09:55 AM
  #684
ktrizzle504's Avatar
i need help also...I have an acura tl 05 made loud noise at the ps pump so i decided to change it. It worked fine until winter hit. when I start the car in the morning it would make a loud whining noise for like 5 seconds. I've been reading alot and I've also been getting alot of answers. Any advice would help. Thanks alot.
1. O ring which I changed it twice.
2. pump out fluid might had air pockets
3. tension pulley and idler pulley
4 crankshaft pulley
I have a video which I can post. But it clearly 90% it sounds like its coming from the ps pump.
This is the video link:
https://www.youtube.com/watch?v=_gV8...ature=youtu.be
Old 01-02-2015, 10:14 AM
  #685
Red89gt's Avatar
Update, MDX has been fine since o-ring and fluid flush. Got 3 more bottles fluid since driven few thousand miles fluid looks black again.
Also did fluid flush on my 08 TL. Was like driveway sealer at 88,000 miles. May trade in for f150 today so may not follow up TL maintenance.
Old 01-08-2015, 09:37 AM
  #686
CobraSpdRH's Avatar
I just did this last weekend on my 04 auto with 96k. Fluid was black but o-ring wasn't completely brittle. Replaced o-ring and flushed PS fluid and no more whine at start-up on colder days. Might flush the ps fluid again as it still doesn't look great, but definite improvement. I only cleaned out my reservoir, didn't replace it. Thanks for the write-up!
Old 01-08-2015, 09:44 AM
  #687
Red89gt's Avatar
I flush and filled my wife's mdx 3 times now at 88k miles and it's finally starting to resemble clean fluid. The first time I took the reservoir out and flushed it out with brake clean as well. All the mdx cold weather ps noise has been cured.
Old 01-09-2015, 12:30 PM
  #688
I'd rather be golfing
adsoldschool's Avatar
Thanks a lot for this thread. I had the whine appear this week, -2 degrees F, go figure. The part was 97 cents, it took me less than 10 minutes start to finish. Next up will be a fluid purge/replace.
Old 01-10-2015, 12:22 PM
  #689
'16 FBP Advance FWD
kfhughes's Avatar
Acurazine to the rescue again
Had this happen on my 06 TL during a cold snap right after Christmas. Found this thread and for $0.82 and ten minutes time replaced the black O-ring with the orange one. Just need to top off the fluid and wait for it to get cold again.
Old 01-12-2015, 10:32 AM
  #690
5th Gear
brownclee's Avatar
(2005 TL) I don have the noise yet, but I suspect that the PS hose or pump are leaking. I just changed the oild yesterday and noticed the front side of the engine is a little wet with oil as well as the bottom and front of the oil pan and bottom of the compressor. The fluid was not dark like the used oil but rather yellowishish like PS fluid. I'm a little puzzled as to how this oil, if it's PS fluid, made to to this area of the engine. The area under the PS pump is a little damp but i can't see an obvious source of the leak. The PS fluid was topped off a few months ago and was below the min line yesterday. Any opinions are welcome.
Old 03-18-2015, 01:42 PM
  #691
4th Gear
Applejuice1's Avatar
I had the whining and froth in the reservoir. I had friend replace the o ring but the whine remains.
I did not notice him lube the new ring when he put it on. Could that be the problem?
Also, a teaspoon or so of psf got on my the belt which he quickly whiped off cause for concern? Thanks.
Old 03-18-2015, 02:14 PM
  #692
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
No concern there, and I don't think the lubing is to blame. That said, it's a 5 minutes job so it might be worth redoing.
Old 03-24-2015, 04:49 PM
  #693
Majofo's Avatar
You don't need to lube the o-ring. In fact, it could interfere if too much was used or it can deteriorate the o-ring if an improper lubricant was applied.
Old 03-29-2015, 12:51 PM
  #694
4th Gear
Thanks.
2 follow ups:
1. Any possible damage being caused by the aeration if I keep an eye on the reservoir level?
2. The dealer said he'd look for cracks in the tubing or poor clamping. If nothing there, a new pump? Sound right to you guys?
Old 04-02-2015, 03:16 PM
  #695
Ryan1340's Avatar
I just did this to my car and it was super easy. The hardest part was getting a wrench around the bolt. I am hoping that this will taker care of the early morning whine. I called around to a few different acura and honda dealers to see what it would have costed for them to do it and the cheapest quote I got was $40-$50 for parts and labor. I also found it strange how much of a price range there was from place to place. I ended up getting the inlet o-ring for $.75 and a bottle of PSF for $4.82 from a acura dealer. I thought a honda dealer would have been cheaper but I guess not.
Old 05-03-2015, 10:55 AM
  #696
BMA1078's Avatar
Mine started whining last week when the weather warmed up, I've never had any of the cold weather incidents that have been reported in this thread.
I don't hear the noise until after I've driven the car a few miles(doesn't do it on start up). I changed the two O-rings on Friday and it's still noisy. The power steering fluid was very dirty, almost black, so I'm hoping doing a fluid flush will resolve the issue.
Old 05-10-2015, 02:20 PM
  #697
BMA1078's Avatar
Update on this, I haven't gotten around to flushing the power steering fluid yet. I have noticed the car only makes the whining noise after it's been on the highway/at higher speeds. I can go in town, stop and go, etc. and it's fine but the minute I get off the interstate it's howling.
Could this possibly be a issue with the hose? My TL never went in for the recall.
Old 05-17-2015, 10:52 AM
  #698
BMA1078's Avatar
Flushed the power steering fluid on Friday, noise is gone!
Old 06-09-2015, 12:19 AM
  #699
samplemonster's Avatar
Mine is also ridiculously loud only after engine warm up. I really hope the fluid replace works
Old 11-22-2016, 06:44 PM
  #700
Majofo's Avatar
Everyone and their mama should know about this.. but it's that time of year again..
Also.. if this doesn't solve it, time to reseal the pump or buy a refub'd one.. just recently changed the pump on the MDX.
Old 11-22-2016, 07:30 PM
  #701
Jeff
Oh Sickest TL's Avatar
I get a little squeal/chrip when I start the TL but I have a feeling its the tensioner/idler thingy
But I'm going to do this anyways. Thanks maj
Old 12-07-2016, 08:10 PM
  #702
9th Gear
Jonjonn420's Avatar
Hello all. I replaced the hose and the joint as well as the o ring and it fixed the whining but there is still bubbles in my reservoir. Any ideas as to why this could be?
Old 12-07-2016, 09:35 PM
  #703
srg818's Avatar
Air is entering the system somewhere. Do you see any leaks?
Old 12-09-2016, 11:29 AM
  #704
Marlon's Avatar
well.. after like 4 years my whine is back. my car wakes up the entire neighborhood on my way to work due to the whining even after warm up. the O-ring didnt do the trick this time so overhaul it is.
  #705
Marlon's Avatar
Old 12-11-2016, 11:43 PM
  #706
9th Gear
Jonjonn420's Avatar
No there is no leaks but the whining came back. Its not as aggressive as it used to be but its still there.
Old 01-13-2017, 11:48 AM
  #707
Ryan Williamson's Avatar
I have the same issue. Also, a whine when engine is warm. Hopefully changing the o-rings will fix this.
Have you had any luck?
Old 02-06-2017, 11:46 AM
  #708
Marlon's Avatar
Hello guys. im having a little bit of an issue here. my whine is back louder and making steering hard.
I replaced the O-rings on both hoses and rebuilt the power steering pump, I put it back and it was working great and super smooth for at least 4 weeks no whine at all even during really cold days. this weekend all of the sudden the whine came back as I was pulling out of the driveway I could not even turn to back out. so I jacked the car up and check the reservoir which was overflowing like crazy with lots of bubbles. one thing is clear.. there is air in the system.
I jacked up the car, flushed the PS fluid, took the reservoir out and completely got all the fluid out. I replaced it with new and clean PS fluid. then whine still there but not as bad and I can turn now. still a little hard but i can drive at least. now what could be wrong? I see no leaks and it only shows the fluid coming out of the reservoir. where can I look next ?
Old 03-02-2017, 03:58 PM
  #709
chao_zu55's Avatar
Whine noise at cold start
Hey guys,
Just bought my car 2016 fall. 2010 TL SH-AWD. I began to hear this whine at the beginning of winter when it was having cold starts. The noise is only there for the initial start after a cold night. If I were to turn off the car and start it again, the noise would disappear. The dealer said it was the tension, so I had that replaced. We had a cold night where I live and the noise is back. Now that I've done more reading on here and found this DIY with the o-ring, however the photos would not load for me. Does anyone have a link or know where I can find the DIY? I hate to bring the car back for such a cheap fix and pay the dealer 100+/hour plus parts.
Thanks guys in advance
Old 03-10-2017, 11:10 AM
  #710
chao_zu55's Avatar
Originally Posted by chao_zu55
Hey guys,
Correction to my last post. The whine is there after several cold starts.**
Old 03-10-2017, 11:37 AM
  #711
Majofo's Avatar
1) Tell the dealer to kiss your ass and give your money back
2) I see the pics.. look for a vid on youtube otherwise, should be at least a couple
Old 03-22-2017, 10:18 AM
  #712
jzhu625's Avatar
does anyone know the part # for power steering fluid? it's for 07 TL-S.
planning to order some online.
Thanks!
Old 03-22-2017, 10:23 AM
  #713
Received 8,584 Likes on 6,630 Posts
Originally Posted by jzhu625
does anyone know the part # for power steering fluid? It's for 07 tl-s.
Planning to order some online.
Thanks!
Amazon Amazon
Old 03-22-2017, 10:29 AM
  #714
jzhu625's Avatar
thanks, when i searched this part #, 08206-9002 and noticed there's another part similar to this one but end with "a" 08206-9002a
08206-9002A | Acura Power Steering Fluid - Bernardi Parts
Old 03-22-2017, 10:31 AM
  #715
08206-9002A Acura Power Steering Fluid - Bernardi Parts
it's the same crap.. one is honda, one is acura.
Old 03-22-2017, 10:40 AM
  #716
jzhu625's Avatar
lolz, i guess "a" stand for Acura!
cool, thanks! i'll order 3 bottles.
one last question, does anyone know the OEM transmission fluid for TL-S? i've been reading all morning and according to some folks saying, DW1 replaced Z1 fluid? this is for AUTO TRANSMISSION.
Thanks!
Old 03-22-2017, 11:42 AM
  #717
Thanks!
DW-1
Old 03-22-2017, 11:44 AM
  #718
jzhu625's Avatar
DW-1
cool and thanks, $7/bottles with my discount not bad.
just type 2 coolant is $16.11 with my discount, not too good but i'll take it!
Old 07-04-2017, 11:02 AM
  #719
sparc's Avatar
I had the pump whine at startup, but the bigger problem was no power steering at low speeds or when trying to park. The other clue was the foam bubbles in the reservoir.
Relatively easy to replace with the proper wrench. I got a harbor freight 10mm stubby wrench from this set: https://www.harborfreight.com/12-pc-...set-61395.html
The box end on the harbor freight 10mm stubby fit the fastener perfectly. It shouldn't take much force to get the bolt loose. Then use your finger to rotate the fastener out.
Prestone power steering fluid is less than $3 at Walmart. There is a Prestone version specifically made for Honda/Acura.
Old 07-16-2017, 11:30 AM
  #720
sparc's Avatar
An update after replacing the inlet o-ring to the pump with the new orange one...
The foam was all gone in the reservoir, but there were still some tiny bubbles being pushed through.
I ended up replacing the black colored outlet o-ring on the top of the pump (Part Number 91370-sv4-000). Those bubbles immediately went away. I noticed that o-ring was stiff and slightly flattened. Not quite as bad as the other inlet o-ring which was almost like a rock, but it definitely needed replacing.
Quick Reply: DIY A-105: Power Steering Whine fix
